sertfirefighter
#1 Posted : Thursday, June 13, 2013 3:51:54 PM(UTC)
sertfirefighter
Water dispenser stopped working after flow rate had decreased. Filter was changed. When you push lever to demand water, the water starts coming out the bottom of the fridge from a tube that is connected to some type of junction valve. Any help would be appreciated in helping me diagnose the problem.
#2 Posted : Friday, June 14, 2013 2:43:23 PM(UTC)
Hello,
Sounds like the problem is a broken water storage line (#810 at the diagram). It is actually a water reservoir for the water dispenser where the water cools down. The solution is to replace it.
- The water storage line Part number: WR17X11324
sertfirefighter
#3 Posted : Saturday, June 15, 2013 4:26:35 AM(UTC)
sertfirefighter
Gene, thanks for the reply. In the back of the fridge there is what appears to be a check valve that has a red cylinder with the line for the ice maker coming out of it, and a blue cylinder right next to it with just a short clear line coming out of that. When you press the switch to demand for water it immediately begins to come out of the short line that is hooked to this check valve. It does not appear to be the line you are speaking of. That line seems to be fine, but I will look at that again. If you have any thoughts on what this valve or the short line is for the input would be great, Thanks
water dispenser sporadically dispenses water (Refrigerator & Freezer Repair)
by ddxxoo 3/20/2024 2:55:42 PM(UTC)
Water dispenser not working GE Profile PSHs6TGXBDS (Refrigerator & Freezer Repair)
by klkaylor78 2/3/2024 11:07:08 AM(UTC)
GE fridge water dispenser slows to trickle, speeds up when filter is twisted (Refrigerator & Freezer Repair)
by Guest 1/11/2024 5:03:35 AM(UTC)
water dispenser stopped working. No light no pwer (Refrigerator & Freezer Repair)
by waterdispprob 11/19/2023 10:08:39 AM(UTC)
Frigidaire Gallery ice maker sending water to water dispenser?? (Refrigerator & Freezer Repair)
by jonny comfort 6/11/2023 7:49:11 PM(UTC)
Frigidaire Refrigerator Ice Maker and Water Dispenser not working (Refrigerator & Freezer Repair)
by kehoetj 5/9/2023 3:57:44 PM(UTC)
Kenmore Coldspot model 106.9555611 Water Dispenser (Refrigerator & Freezer Repair)
by reynolpe 2/14/2023 1:40:10 PM(UTC)
LG Fridge - Water Dispenser barely flowing (Refrigerator & Freezer Repair)
by AZ_Desert 1/28/2023 7:03:14 AM(UTC)
Ice Maker not filling with water. Water dispenser works. Kenmore Elite (Refrigerator & Freezer Repair)
by jeffrich12 1/21/2023 9:13:34 AM(UTC)
Frigidaire ice maker and water dispenser not working (Refrigerator & Freezer Repair)
by goozpah 1/20/2023 6:39:18 AM(UTC)
Whirlpool Refrigerator inside lights, ice and water dispenser doesn't work (Refrigerator & Freezer Repair)
by Guest 1/6/2023 5:15:20 PM(UTC)
electrolux fridge Water dispenser doesn’t work (Refrigerator & Freezer Repair)
by max57 10/28/2022 2:33:45 PM(UTC)
Electrolux Refrigerator Water Dispenser Sticks Open (Refrigerator & Freezer Repair)
by Thom64 7/30/2022 8:42:45 AM(UTC)
Kenmore water dispenser line (Refrigerator & Freezer Repair)
by rkgamble50 6/13/2022 8:55:16 AM(UTC)
@! Kitchenaid KBSD612ESS00 Screen, Ice & Water Dispenser Stopped Working !@ (Refrigerator & Freezer Repair)
by davenlei 6/9/2022 9:11:16 AM(UTC)
