Have cover off ice maker while still hooked up. It made ice after I swaped water dispence line on valve to make sure it had a full tray of water, then swapped them back to normal.Marked motor (small) gear in reference to large dispensing gear, and found it has not moved in 24hours of installing it. This was a replacement for the original which had a short in the ice cube tray heater element. How often should it dump? What drives or what sends power to the ice maker drive motor? Does the defrost timer send power to ice maker, or does ice maker work independently? Does anyone have a wire diagram for this model?
