Discuss
Upright freezer, only freezing on bottom shelf
 in
Refrigerator & Freezer Repair
I setup my upright freezer which was off for a while. A few hours later, i filled it with food.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Upright freezer, only freezing on bottom shelf
  #1 (permalink)
Old 05-28-2013, 09:03 AM
Junior Member
yossissiegel is on a distinguished road
Default Upright freezer, only freezing on bottom shelf
Model Number: 2539244411   Brand: Kenmore   Age: 5 - 10 years
I setup my upright freezer which was off for a while. A few hours later, i filled it with food. When I returned 24 hours later, only the stuff all the way at the bottom was frozen solid. Everything else was cold but defrosted. I could not feel any air coming out of the vents on the top back wall. I turned it off, emptied it, and removed the back panel. The coils were mostly iced over. After they defrosted, I turned it back on. The fan spins and there is now cold air circulating. The coils are staring to freeze over again. What is the most likely cause? Should I be replacing the defrost timer as the first repair to see if that does it? If so, for my kenmore 2539244411, is the part # 5308037967 or 297318010 ? Is this something I could replace on my own with very little skill working on appliances?
Related Models
Kenmore 2539244411 UPRIGHT FREEZER
Kenmore 2539246410 UPRIGHT FREEZER
Kenmore 2539246411 UPRIGHT FREEZER
Kenmore 2539251310 UPRIGHT FREEZER
Kenmore 2539252110 UPRIGHT FREEZER
Kenmore 2539252210 UPRIGHT FREEZER
Kenmore 2539253280 UPRIGHT FREEZER
Kenmore 2539260210 UPRIGHT FREEZER
Kenmore 2539260211 UPRIGHT FREEZER
Kenmore 2539260212 UPRIGHT FREEZER
Kenmore 2539260410 UPRIGHT FREEZER
Kenmore 2539260411 UPRIGHT FREEZER
Kenmore 2539260412 UPRIGHT FREEZER
Kenmore 2539261110 UPRIGHT FREEZER
Kenmore 2539262010 UPRIGHT FREEZER
Kenmore 2539262011 UPRIGHT FREEZER
Kenmore 2539264110 UPRIGHT FREEZER
Kenmore 2539264111 UPRIGHT FREEZER
Kenmore 2539264210 UPRIGHT FREEZER
Kenmore 2539264211 UPRIGHT FREEZER
Kenmore 2539264212 UPRIGHT FREEZER
Kenmore 2539266210 UPRIGHT FREEZER
Kenmore 2539266211 UPRIGHT FREEZER
Kenmore 2539266212 UPRIGHT FREEZER
Kenmore 2539266410 UPRIGHT FREEZER
Kenmore 2539266411 UPRIGHT FREEZER
Kenmore 2539266412 UPRIGHT FREEZER
Kenmore 2539267110 UPRIGHT FREEZER
Kenmore 2539269010 UPRIGHT FREEZER
Kenmore 2539269011 UPRIGHT FREEZER
Kenmore 2539274010 UPRIGHT FREEZER
Kenmore 2539276010 UPRIGHT FREEZER
Kenmore 2539276011 UPRIGHT FREEZER
Kenmore 2539280210 UPRIGHT FREEZER
Kenmore 2539280212 UPRIGHT FREEZER
Kenmore 2539280213 UPRIGHT FREEZER
Kenmore 2539280214 UPRIGHT FREEZER
Kenmore 2539280215 UPRIGHT FREEZER
Kenmore 2539280410 UPRIGHT FREEZER
Kenmore 2539280411 UPRIGHT FREEZER
Kenmore 2539280412 UPRIGHT FREEZER
Kenmore 2539280413 UPRIGHT FREEZER
Kenmore 2539280415 FREEZER
Kenmore 2539280810 UPRIGHT FREEZER
Kenmore 2539280811 UPRIGHT FREEZER
Kenmore 2539280812 UPRIGHT FREEZER
Kenmore 2539280850 UPRIGHT FREEZER
Kenmore 2539280851 UPRIGHT FREEZER
Kenmore 2539280852 UPRIGHT FREEZER
Kenmore 2539281110 UPRIGHT FREEZER
Kenmore 2539282010 UPRIGHT FREEZER
Kenmore 2539282110 UPRIGHT FREEZER
Kenmore 2539284010 UPRIGHT FREEZER
Kenmore 2539284011 UPRIGHT FREEZER
Kenmore 2539284012 UPRIGHT FREEZER
Kenmore 2539284013 UPRIGHT FREEZER
Kenmore 2539284014 FREEZER
Kenmore 2539284015 UPRIGHT FREEZER
Kenmore 2539284017 FREEZER
Kenmore 2539284110 UPRIGHT FREEZER
Kenmore 2539284113 FREEZER
Kenmore 2539284210 UPRIGHT FREEZER
Kenmore 2539284211 UPRIGHT FREEZER
Kenmore 2539284212 UPRIGHT FREEZER
Kenmore 2539284213 UPRIGHT FREEZER
Kenmore 2539284214 UPRIGHT FREEZER
Kenmore 2539284215 UPRIGHT FREEZER
Kenmore 2539287110 UPRIGHT FREEZER
Kenmore 2539287210 UPRIGHT FREEZER
Kenmore 2539287212 UPRIGHT FREEZER
Kenmore 2539287213 UPRIGHT FREEZER
Kenmore 2539287214 FREEZER
Kenmore 2539287215 FREEZER
Kenmore 2539287410 UPRIGHT FREEZER
Kenmore 2539287412 UPRIGHT FREEZER
Kenmore 2539287413 UPRIGHT FREEZER
Kenmore 2539287414 UPRIGHT FREEZER
Kenmore 2539287415 UPRIGHT FREEZER
Kenmore 2539289110 UPRIGHT FREEZER
Kenmore 2539289111 FREEZER
Kenmore 2539289112 UPRIGHT FREEZER
Kenmore 2539289114 UPRIGHT FREEZER
Kenmore 2539305285 REFRIGERATOR
Kenmore 2539305287 REFRIGERATOR
Kenmore 2539335001 TOP-MOUNT REFRIGERATOR
Kenmore 2539335011 TOP-MOUNT REFRIGERATOR
Kenmore 2539335081 TOP-MOUNT REFRIGERATOR
Kenmore 2539335091 TOP-MOUNT REFRIGERATOR
Kenmore 2539335201 REFRIGERATOR
Kenmore 2539335211 REFRIGERATOR
Kenmore 2539335281 REFRIGERATOR
Kenmore 2539335291 REFRIGERATOR
Kenmore 2539337001 REFRIGERATOR
Kenmore 2539337011 REFRIGERATOR
Kenmore 2539337081 REFRIGERATOR
Kenmore 2539337091 REFRIGERATOR
Kenmore 2539337201 REFRIGERATOR
Kenmore 2539337211 REFRIGERATOR
Kenmore 2539337281 REFRIGERATOR
Kenmore 2539337291 REFRIGERATOR
Kenmore 2539337701 REFRIGERATOR
Kenmore 2539337711 REFRIGERATOR
Kenmore 2539337781 REFRIGERATOR
Kenmore 2539337791 REFRIGERATOR
Kenmore 2539338001 REFRIGERATOR
Kenmore 2539338011 REFRIGERATOR
Kenmore 2539338081 REFRIGERATOR
Kenmore 2539338091 REFRIGERATOR
Kenmore 2539338101 REFRIGERATOR
Kenmore 2539338111 REFRIGERATOR
Kenmore 2539338181 REFRIGERATOR
Kenmore 2539338191 REFRIGERATOR
Kenmore 2539338201 REFRIGERATOR
Kenmore 2539338211 REFRIGERATOR
Kenmore 2539338281 REFRIGERATOR
Kenmore 2539338291 REFRIGERATOR
Kenmore 2539338701 REFRIGERATOR
Kenmore 2539338711 REFRIGERATOR
Kenmore 2539338781 REFRIGERATOR
Kenmore 2539338791 REFRIGERATOR
  #2 (permalink)
Old 05-28-2013, 12:04 PM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Kenmore Freezer 2539244411 - AppliancePartsPros.com
Since the evaporator coils were iced up to the point where the fan could not pull air through them you are on the right track about it being a defrost proble.
I would not just replace parts a little trouble shooting will save youself some money.
There are 3 parts in the defrost circuit, the timer, the defrost heater and the defrost thermostat.
Let the freezer get cold again
Then remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
Manually force a defrost cycle by turning the defrost timer cam till the fans and compressor turn off.
Your timer looks like it is at the back of the unit near the floor. You may not be able to see the timer itself as it is probably mounted behind a bracket but there is usually a hole in the bracket to let you turn the timer cam.
The cam can only turn in one direction, actually a screw driver can only engage the cam in one direction.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (under the evaporator/freezer coils) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (clipped to the top of the evaporator coils) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Click on the below picture for more info/views of the timer.
Part number: 216744400
__________________
  #3 (permalink)
Old 05-28-2013, 02:20 PM
Junior Member
Default
Thanks will do step one, once the coils free over again. In the meantime, to test for continuity, I will follow the steps listed on the sticky for this forum. Will any "digital multimeter" work for that?
  #4 (permalink)
Old 05-28-2013, 05:28 PM
Junior Member
Default
Okay, I let the coils freezup. I then manually turned the timer until the condenser and fan turned off. The heating rod immediately got very hot. Is it same to assume that my next step should be to replace the timer?
  #5 (permalink)
Old 05-28-2013, 05:41 PM
Senior Expert
APP Volunteer
Default
Yes.
Since it turned on you know that the defrost heater and defrost thermostat are OK.
__________________
  #6 (permalink)
Old 06-03-2013, 02:52 PM
Junior Member
Default
hey just wanted to report back, I replaced the defrost time and the issue is resolved! the problem now is that the freezer is always on, except when the defrost timer kicks in. When i lower the temp setting, it clicks and turns off, but whatever # i have it set to, it never turns off. What are my next steps?
  #7 (permalink)
Old 06-04-2013, 02:06 AM
Senior Expert
APP Volunteer
Default
Check your compartment temperatures.
The freezer should be 0 to 5 degrees F.
__________________
  #8 (permalink)
Old 06-04-2013, 05:34 AM
Junior Member
Default
It's measuring around 6 degrees F
  #9 (permalink)
Old 06-04-2013, 10:38 AM
Senior Expert
APP Volunteer
Default
Is the freezer fan runnig?
If not check across it for 120 volts.
If you have 120 volts then the fan need replacing.
Remove the cover in the freezer so that you can inspect the evaporator coils.
If they are only partially frosted over (usually where the freon enters the coils) then you probably have a sealed system problem.
This will be an expensive repair as you need a pro. Often it makes more sense to put those dollars towards a new unit.
Be sure that the compressor has run for at least an hour because if you do this check during or shortly after a defrost cycle you could end up with the wrong conclusion.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Upright Freezer - Only Top Shelf Cooling akspencefamily Refrigerator & Freezer Repair 1 10-13-2012 12:51 AM
Freezer Bottom Shelf Only Freezing clsoule Refrigerator & Freezer Repair 1 07-14-2011 09:42 AM
refrige&Freezer only cooling bottom shelf MilwaukeeJoe Refrigerator & Freezer Repair 2 12-28-2010 09:36 PM
My Frigidare Upright Freezer not freezing acshort Refrigerator & Freezer Repair 1 04-03-2010 10:28 PM
freezer works on bottom shelf only tommy R. Refrigerator & Freezer Repair 2 03-17-2009 03:48 PM
