Discuss
Viking 36" All Refrigerator Condensate Drain
 in
Refrigerator & Freezer Repair
My 36" Viking All Refrigerator is dripping onto the floor instead of the pan. I would imagine the drain line
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Viking 36" All Refrigerator Condensate Drain
  #1 (permalink)
Old 05-26-2013, 11:46 AM
Junior Member
RichardU is on a distinguished road
Default Viking 36" All Refrigerator Condensate Drain
Brand: -other-   Age: 1 - 5 years
My 36" Viking All Refrigerator is dripping onto the floor instead of the pan. I would imagine the drain line is clogged.
Can anyone please tell me where to find the drain line or how to clean it?
  #2 (permalink)
Old 05-28-2013, 05:42 AM
Junior Member
Default
Are service manuals available for Viking?
  #3 (permalink)
Old 05-28-2013, 07:03 PM
Member
VikTech is on a distinguished road
Default
Quote:
Yes but only for authorized servicers. Your evaporator is located on the back wall at the top. There is a drain trough under the evap and the drain tube is on the left. It's not common for the drain to be clogged due to its location.
A little lower than half way down on the rear wall look for icing. There is a secondary evap that could be iced over due to a refrigerant leak or failed fan.
  #4 (permalink)
Old 05-29-2013, 02:47 PM
Junior Member
Default
Thanks for your reply. Is this accessible from inside or will I need to pull the unit out of the cabinet?
  #5 (permalink)
Old 06-03-2013, 10:58 AM
Junior Member
Default
Does anyone else have any insight on how to access the drain line on a Viking refrigerator?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Viking 15" Ice Machine Grid Cutter Failure jsterling Refrigerator & Freezer Repair 0 04-09-2012 10:47 PM
Washer will only drain if put on "Drain+Spin" cycle. Arieleno Washer Repair 7 11-02-2011 07:03 PM
Viking Gas Wall Oven 27" vikingb Oven Repair (including Ranges and Cooktops) 0 03-08-2010 02:48 PM
Viking 36" cooktop won't ignite fercra11 Oven Repair (including Ranges and Cooktops) 0 07-23-2009 01:07 PM
Viking Bottom Freezer - Condensate Frozen dgbrong Refrigerator & Freezer Repair 1 03-31-2008 01:07 PM
