Kenmore side by side fridge and freezer. The ice tray is stuck/frozen in the dump position. This happened about a week ago also. I had shut off the ice maker switch overnight. When I turned it back on the next day the tray went up and it started making ice again. Now this has happened again and the shutting off trick did not work this time. Any thoughts?
