Diana L
#1 Posted : Saturday, May 25, 2013 5:24:16 AM(UTC)
Diana L
I have a whirlpool gold refridgerator. It is about 8-10 years old. It has a top freezer that keeps freezing up so I endd up with ice across the whole freezer bed and water all over the fridge. This has happened now for the 4th time in about 18 months. I had an appliance repair person out the 1st time but he didn't think there was a problem with any motor or fan parts so now every time it happens, I empty it and unplug it for 24 hours. Have you had this reported before? I don't want to pay for another service call for defrosting.
#2 Posted : Sunday, May 26, 2013 1:49:29 AM(UTC)
A model number may help others help you.
Find your model number - AppliancePartsPros.com
It sounds like you have a drain problem.
The water created by the defrost cycle is not draining down the drain tube into the drip tray under the unit.
I would check that the drain tube is clear.
If plugged a turkey baster with warm water, an air compressor with low pressure or a wire can often be used to clear it.
Also check that it is not plugged with dust etc. at the drain pan end.
You might as well clean the condenser/compressor fan and the condenser coils while you are down there.
If it looks like stuff is growing in the tube I would flush it with a 10% bleach solution. This should kill the stuff and let you flush it out. You may have to do this several times, let it sit for 15 minutes or so between flushes.
Be careful that the drip tray does not overflow and empty the drip tray after you are done.
Be sure to unplug the unit while doing this.
Also check that the path the water takes from the evaporator coils to the drain is clean. Anything that slows down the draining will cause a ice build up until finally the drain clogs. A light coating of buffed up wax can sometimes help the water drain quicker.
If none of the above help then there is a jiggery pokery fix that adds a drain heater to the drain but this depends on the model.
Samsung Fridge and freezer incorrect temps (Refrigerator & Freezer Repair)
by Guest 4/3/2024 9:24:02 AM(UTC)
Ice Buildup Under Freezer Platform, Leaks into Fridge (Refrigerator & Freezer Repair)
by MochaFiend 4/2/2024 3:21:56 PM(UTC)
Freezer temperature varying (Refrigerator & Freezer Repair)
by Guest 4/2/2024 6:15:22 AM(UTC)
GE Profile Freezer Wildly Varying Temps (Refrigerator & Freezer Repair)
by Guest 3/26/2024 3:54:40 PM(UTC)
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 3/5/2024 11:02:19 AM(UTC)
Whirlpool Gold GD5SHA Freezer Temperature Rises Overnight (Refrigerator & Freezer Repair)
by jrb98391 2/22/2024 10:20:17 AM(UTC)
Intermittent fridge/freezer (Refrigerator & Freezer Repair)
by Hystiker 2/21/2024 4:01:30 PM(UTC)
Bottom Freezer Leaking Water (Refrigerator & Freezer Repair)
by fscel 2/13/2024 11:22:53 AM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
Whirlpool french door w/ bottom freezer (Refrigerator & Freezer Repair)
by JumperWire 2/11/2024 1:41:25 PM(UTC)
Kenmore refrigerator/freezer issue (Refrigerator & Freezer Repair)
by rgbradley58 1/30/2024 6:32:20 AM(UTC)
Frigidaire Freezer Handle (Refrigerator & Freezer Repair)
by Guest 1/21/2024 12:46:23 PM(UTC)
Frigidaire upright freezer to warm (Refrigerator & Freezer Repair)
by jrklund311 1/11/2024 2:51:18 PM(UTC)
Frigidaire Gallery Refrigerator GRFS2853AF4 - Freezer not working (Refrigerator & Freezer Repair)
by Repaircat 1/9/2024 8:08:53 AM(UTC)
Frigidaire upright freezer temperature display acting strangely (Refrigerator & Freezer Repair)
by redroverguy 1/1/2024 11:34:30 AM(UTC)
