Discuss
Stand Alone Full Size Water Cooler - Water freeze.
 in
Refrigerator & Freezer Repair
I realize this is the forum for Refrigerators but I did not see a section that better suited my inquiry,
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Stand Alone Full Size Water Cooler - Water freeze.
  #1 (permalink)
Old 05-09-2013, 12:16 PM
Junior Member
Mahoraba is on a distinguished road
Default Stand Alone Full Size Water Cooler - Water freeze.
Model Number: PWD885BLP -1 (3)   Brand: -other-   Age: 1 - 5 years
I realize this is the forum for Refrigerators but I did not see a section that better suited my inquiry, sorry in advance for where I've placed this.
Generally a Water Line freeze is easily fixed by adjusting the Thermostat to a warmer setting but this specific Water Cooler does not have an Adjustable Thermostat, the digital display in the front is the only way to adjust it and it will only let you adjust it a very limited amount.
This Water cooler has Hot and Cold water and it has a small fridge at the bottom. The Hot water temperature on the digital display displays correctly when I turn the Hot switch on, it will rise and it will stop when it reaches 90 degrees F like its suppose to.
But the cold side reads 99 degrees F and 51 degrees C at all times, no matter what, this is causing the water to perpetually continue cooling and eventually, freezing and I'm not exactly sure what I can do about it.
I've taken the back off and looked at it just to see if I could find some kind of adjuster or something but none exists not under a sticker, not behind a panel, no where.
http://www.comstatinc.com/images/thermo.jpg
The left-most one on that picture is the thing that I've been able to determine is a pre-set Thermostat and that must be the one for the Hot side (Since the Hot side is unable to be changed, a pre-set Thermostat is Ideal and was probably cost efficient when they were building these).
Now, I only see one of those and I cannot find anything else that looks anything like a thermostat, I've followed the Compressors cords every which way and have come up with nothing, but since the Hot side thermostat is working and stops when It needs to stop and reads correctly, that the Control board itself is fine and its just a thermal switch somewhere that needs adjusted/replaced?
Related Models
General Electric PWG25SGSACSS Refrigerator
General Electric PWG25SGSBCSS Refrigerator
General Electric PWR04FANABB Refrigerator
General Electric PWR04FANABS Refrigerator
General Electric PWR04FANBBB Refrigerator
General Electric PWR04FANBBS Refrigerator
General Electric PWT26SGPAKSS Refrigerator
General Electric PWT26SGPBKSS Refrigerator
General Electric PWT26SGRCKSS Refrigerator
General Electric PWT26SGRDSS Refrigerator
General Electric PWT26SGRESS Refrigerator
General Electric PXRQ15F00 Wh filt sys
Maytag PYE1000AYW DRYER- ELE
Maytag PYE1000AZW DRYER- ELE
Admiral PYE2000AKE DRYER- ELE
Maytag PYE2000AYW DRYER- ELE
Maytag PYE2000AZW DRYER- ELE
Admiral PYE2000GGE DRYER- ELE
Admiral PYE2200AKW DRYER- ELE
Maytag PYE2200AYW DRYER- ELE
Maytag PYE2200AZW DRYER- ELE
Maytag PYE2300AYW DRYER- ELE
Maytag PYE2300AZW DRYER- ELE
Admiral PYE3200AGW DRYER- ELE
Maytag PYE3200AYW DRYER- ELE
Maytag PYE3200AZW DRYER- ELE
Admiral PYE3300AGW DRYER- ELE
Admiral PYE3300AKW DRYER- ELE
Maytag PYE3300AYW DRYER- ELE
Maytag PYE3300AZW DRYER- ELE
Maytag PYE3360AYW DRYER- ELE
Maytag PYE4500AYQ DRYER- ELE
Maytag PYE4500AYW DRYER- ELE
Maytag PYE4500AZW DRYER- ELE
Maytag PYE4557AYW DRYER- ELE
Maytag PYE4558AYW DRYER- ELE
Maytag PYET244AYW DRYER- ELE
Maytag PYET244AZW DRYER- ELE
Maytag PYET344AYW DRYER- ELE
Maytag PYET344AZW DRYER- ELE
Maytag PYET444AYW DRYER- ELE
Maytag PYET444AZW DRYER- ELE
Maytag PYG1000AWW DRYER- GAS
Maytag PYG2000AWW DRYER- GAS
Maytag PYG2200AWW DRYER- GAS
Admiral PYG2300AGW DRYER- GAS
Maytag PYG2300AWW DRYER- GAS
Maytag PYG3200AWW DRYER- GAS
Maytag PYG3250AWW DRYER- GAS
Maytag PYG3300AWW DRYER- GAS
Maytag PYG3360AWW DRYER- GAS
Maytag PYG4500AWQ DRYER- GAS
Maytag PYG4500AWW DRYER- GAS
Maytag PYG4557AWW DRYER- GAS
Maytag PYG4558AWW DRYER- GAS
Admiral PYGS244AWW DRYER- GAS
Maytag PYGT244AWW DRYER- GAS
Maytag PYGT344AWW DRYER- GAS
Maytag PYGT444AWW DRYER- GAS
Amana QDO-695 RANGE- S/C S/I DDRAFT GAS
Amana QDO-695D RANGE- S/C S/I DDRAFT GAS
Amana QDO-695E RANGE- S/C S/I DDRAFT GAS
Amana QDO-695F RANGE- S/C S/I DDRAFT GAS
Amana QDO-695G RANGE- S/C S/I DDRAFT GAS
Amana QDO-695H RANGE- S/C S/I DDRAFT GAS
Amana QDU-838 RANGE- S/C S/I DDRAFT GAS
Amana QDU-858 RANGE- S/C S/I DDRAFT GAS
Amana QDU-878 RANGE- S/C S/I DDRAFT GAS
Amana QDU-966 RANGE- S/C S/I DDRAFT GAS
Amana QDU-976 RANGE- S/C S/I DDRAFT GAS
Amana QKO-661 RANGE- S/C S/I DDRAFT GAS
Amana QKO-661B RANGE- S/C S/I DDRAFT GAS
Amana QKO-661C RANGE- S/C S/I DDRAFT GAS
Amana QKO-661D RANGE- S/C S/I DDRAFT GAS
Amana QKO-661E RANGE- S/C S/I DDRAFT GAS
Amana QKO-751 RANGE- S/C S/I DDRAFT GAS
Amana QKO-751A RANGE- S/C S/I DDRAFT GAS
Amana QKU-647 RANGE- S/C S/I DDRAFT GAS
Amana QKU-647A RANGE- S/C S/I DDRAFT GAS
Amana QMC811 WALLOVEN- STD MWAVE ELE
Amana QMD-800 MWAVE - FAMILY SIZE (60 HZ)
Amana QMD-800D MWAVE - FAMILY SIZE (60 HZ)
Amana QMD-800E MWAVE - FAMILY SIZE (60 HZ)
Amana QMD-810 MWAVE - FAMILY SIZE (60 HZ)
Amana QMD800 WALLOVEN- STD MWAVE ELE
Amana QMD800D MWAVE - FAMILY SIZE (60 HZ)
Amana QMD810 WALLOVEN- STD MWAVE ELE
Amana R-1 RANGE- S/C S/I DDRAFT GAS
Amana R-1H RANGE- S/C S/I DDRAFT GAS
Amana R-1J RANGE- S/C S/I DDRAFT GAS
Amana R-1J MWAVE - FAMILY SIZE (60 HZ)
Amana R-2 RANGE- S/C S/I DDRAFT GAS
Amana R-3 RANGE- S/C S/I DDRAFT GAS
Amana R-3 MWAVE - FAMILY SIZE (60 HZ)
Amana R0-24-8 MWAVE - FAMILY SIZE (60 HZ)
Amana R0-24-8 MWAVE- MOUNTED OVER RANGE/WO
Whirlpool R101 Air-conditioner/heat pump
Whirlpool R1011 Air-conditioner/heat pump
Whirlpool R1012 Air-conditioner/heat pump
Whirlpool R1013 AIR CONDITIONER
Whirlpool R1014 AIR CONDITIONER
Whirlpool R121 Air-conditioner/heat pump
Whirlpool R1211 Air-conditioner/heat pump
Whirlpool R1212 AIR CONDITIONER
Whirlpool R1213 AIR CONDITIONER
Whirlpool R1231 Air-conditioner/heat pump
 R1404 Air Conditioner
Whirlpool R141A AIR CONDITIONER
Whirlpool R141A1 AIR CONDITIONER
Whirlpool R141F0 AIR CONDITIONER
Whirlpool R141G0 AIR CONDITIONER
Amana R15 MISC / ACCESSORY
Whirlpool R153 Air-conditioner/heat pump
Amana R15A MISC / ACCESSORY
Amana R15L MISC / ACCESSORY
Amana R15LA MISC / ACCESSORY
Whirlpool R183 AIR CONDITIONER
Whirlpool R183A AIR CONDITIONER
  #2 (permalink)
Old 05-10-2013, 09:01 AM
Junior Member
Default
I've been able to deduce the exact wire that runs into where the Cold water is and found that this paticular Water cooler uses a 2 Pin Thermal Sensor wire that goes into the foam (Not sure If it continues to go into where the water is, unsure If I can just yank it out, there's tape around where it is.) Unplugging this wire, gives the control board an error for the Cold response, indicating that it is indeed that 2 pin wire that runs into the foam covered water bowl.
I now just need to know if its safe to remove the current wire running into the Bowl and if it is, what kind of 2pin thermal sensor wire to buy since most wires seem to be designed for a computer motherboard, I'm unsure if one of those would work.
  #3 (permalink)
Old 05-11-2013, 09:55 AM
Junior Member
Default
Upsetting that I've yet to get a single comment.. Oh well I suppose I'll keep at it.
Since I know that the Hot Thermal Sensor Wire works and detects the temp of the Hot side and I haven't ever and probably will never use the Hot side, I figure I could take the Thermal Sensor wire from the Hot side and use it to detect on the Cold side instead, Yes?
Unless Hot/Cold Thermal Sensor Wires have any reason to detect resistance differently which I suspect that they might, that should work to simply take the Hot wire and place it for Cold.
Reguardless of if that would work or not, These wires go into the Foam Bowl that I believe covers a metal bowl that holds these wires onto the bowl itself, If this is indeed how it is then I should be able to cut the foam around where the Wire goes into the bowl and then take the wire out of where its positioned, Yes/No?
  #4 (permalink)
Old 05-11-2013, 11:11 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
The probable reason that you have not received any replies is that no one can find any tech data on the unit.
I would disconnect the thermistors at the control board and read their resistance values with a meter.
If you have a resistance then they are probably OK.
It will likely be in the upper Kohms.
They may or may not be the same.
Google "thermistor specs" and you will see what is normal resistance for some of them.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Water Cooler elaraujo Refrigerator & Freezer Repair 0 03-28-2013 09:48 AM
G E Water Cooler Garydj Refrigerator & Freezer Repair 0 02-08-2011 07:42 PM
BOSCH SMS69L02 Full size Dishwasher mini4444 Dishwasher Repair 0 01-13-2011 10:01 AM
water cooler emerald487 General Talk 0 01-01-2009 08:42 AM
GE Water cooler gwerdin General Talk 1 11-20-2008 02:27 PM
