danwcope
#1 Posted : Sunday, April 28, 2013 7:01:07 AM(UTC)
danwcope
My refrigerator stops cooling (frozen food starts to defrost, light is on but no fan or compressor running).
If I unplug the unit for a minute or two and plug it back in, everything comes back on and runs fine for a few days.
Whirlpool
Model ET1MTKXKT01
Serial EL4528863
Any thoughts?
Thanks in advance,
Dan
#2 Posted : Monday, April 29, 2013 5:14:06 AM(UTC)
Parts for Whirlpool ET1MTKXKT01 Refrigerator - AppliancePartsPros.com
Since unplugging it, resets it. It sounds like an electronic problem and this points to the adaptive defrost control board (item 4 in the Liner Parts section) re: it is getting stuck in a defrost cycle.
To raise the odds of it being this part try turning the temperature control up/down a bit. Do not turn it off.
If it fires up then it could the the control thermostat.
If it does nothing then odds are higher that it is the defrost board.
danwcope
#3 Posted : Monday, April 29, 2013 1:27:02 PM(UTC)
danwcope
Any harm in putting it on a timer to shut off for 15 min each day so I don't lose anything in the freezer until I replace the control unit?
Thx,
Dan
#4 Posted : Tuesday, April 30, 2013 7:50:32 AM(UTC)
[COLOR="Blue"]Any harm in putting it on a timer to shut off for 15 min each day so I don't lose anything in the freezer until I replace the control unit?[/COLOR]
I am not sure if this will stop the defrost cycle from running.
But even if it does the evaporator coils will freeze over and cause problems.
Refrigerator stops cooling (Refrigerator & Freezer Repair)
by wamay01 7/10/2014 6:27:31 AM(UTC)
Refrigerator stops cooling every 24 hours (Refrigerator & Freezer Repair)
by car377 8/20/2013 1:00:24 PM(UTC)
Refrigerator stops cooling but restarts (Refrigerator & Freezer Repair)
by logans72 4/8/2012 6:51:07 AM(UTC)
Whirlpool refrigerator stops cooling, intermittently (Refrigerator & Freezer Repair)
by trogers2000 3/7/2012 4:30:08 PM(UTC)
Refrigerator stops cooling. (Refrigerator & Freezer Repair)
by gatheringgrounds 10/8/2011 4:52:22 PM(UTC)
refrigerator stops cooling when freezer door is closed (Refrigerator & Freezer Repair)
by montegonian62 3/3/2011 11:01:30 AM(UTC)
by Tom Kataras 6/24/2010 5:34:02 AM(UTC)
Refrigerator stops cooling when freezer door is closed (Refrigerator & Freezer Repair)
by OrangeGirl95 6/11/2009 6:03:15 AM(UTC)
by Joseph Rotenberg 3/13/2009 9:46:57 AM(UTC)
Refrigerator stops cooling after a few hours (Refrigerator & Freezer Repair)
by MNelson 11/13/2008 2:57:01 PM(UTC)
Freezer and Refrigerator stops cooling (Refrigerator & Freezer Repair)
by ckruss 5/31/2008 5:46:05 PM(UTC)
