The water/ice dispenser of my fridge not dispense ice from the ice bin. The water part is fine and it has no problem to dispense water. When I push the latch, there is no humming sound. Would this be the motor issue?
Thanks for any help.
Groups: APP Team
Hi. Does the ice door opens when you push the lever? If it doesn't, then most likely it's a broken micro switch or bracket.If it does - bad dispenser motor. You also should check if the wires down at the freezer bottom hinge are OK. Here are the breakdown diagrams and http://cdn.appliancepart...ms/dcache/29289596_2.gifPost the results. Simon.
