Discuss
SubZero 550 Freezer won't come on
 in
Refrigerator & Freezer Repair
The freezer on our subzero keeps getting stuck off. If I check voltage across the thermostat wires at the defrost
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » SubZero 550 Freezer won't come on
  #1 (permalink)
Old 04-12-2013, 08:48 PM
Junior Member
Beadpimp is on a distinguished road
Default SubZero 550 Freezer won't come on
Model Number: 550   Brand: Sub Zero   Age: More than 10 years
The freezer on our subzero keeps getting stuck off. If I check voltage across the thermostat wires at the defrost timer, I get around 3 to 6 volts, if that means anything. When I unplug wires from the thermostat to test, I get the full 120, and once I plug it back in, everything's fine. I've already replaced the thermostat and it did the same thing a week later.
This time, it happened because our freezer was freezing closed and my wife turned the thermostat down to let it thaw and it wouldn't come back up. I think the last two times it has happened it was when we were out for several days.
The last time I messed with it, I was trying to figure out a why to get it working without taking the thermostat back apart. I had the defrost timer disconnected and the breaker off for a while. When I put everything back together, the refrigerator compressor kicked in, but I heard several clicks, maybe a minute apart, for several minutes, before it finally did. I don't know if that is normal either, but the freezer compressor didn't kick on until the refrigerator compressor did.
Related Models
Amana 550 COMMERCIAL MICROWAVES
Amana 550.014 COMMERCIAL MICROWAVES
Amana 550.015 COMMERCIAL MICROWAVES
Amana 550.017 COMMERCIAL MICROWAVES
Amana 550.018 COMMERCIAL MICROWAVES
Amana 550.019 COMMERCIAL MICROWAVES
Hoover 5503
Admiral 550AH RANGE- F/S STD ELE
Admiral 550HH RANGE- F/S STD ELE
Admiral 550WH RANGE- F/S STD ELE
Frigidaire 5559B AIR CONDITIONER
Frigidaire 5565B AIR CONDITIONER
Magic Chef 55HA-1W RANGE- D/I STD ELE
Magic Chef 55HA-3LX RANGE- D/I STD ELE
Magic Chef 55HN-1W RANGE- D/I STD ELE
Magic Chef 55HN-3LX RANGE- D/I STD ELE
Frigidaire 56-1007-10-01 Tap(v1) / Microwave
Frigidaire 56-1007-10-02 Tap(v1) / Microwave
Frigidaire 56-1007-10-03 Tap(v1)
Frigidaire 56-1029-10-01 Tap(v1) / Microwave
Frigidaire 56-1030 MICROWAVE OVEN
Frigidaire 56-1030-10-01 Tap(v1) / Microwave
Frigidaire 56-1037-10-01 Tap(v2) / Microwave
Frigidaire 56-1037-10-02 Tap(v2) / Microwave
Frigidaire 56-1037-10-03 Tap(v2)
Frigidaire 56-1039-10-01 Tap(v2) / Microwave
Frigidaire 56-1040-00-01 Tap(v2) / Microwave
Frigidaire 56-1040-10-01 Tap(v1) / Microwave
Frigidaire 56-1207-10-01 Tap(v1)
Frigidaire 56-1207-23-01 Tap(v2)
Frigidaire 56-1246-00-04 Tap(v2) / Microwave
Frigidaire 56-1246-10-04 Tap(v1) / Microwave
Frigidaire 56-2068-10-01 Tap(v1) / Microwave
Frigidaire 56-2077-10-01 Tap(v3) / Microwave
Frigidaire 56-2077-10-02 Tap(v3) / Microwave
Frigidaire 56-2077-10-03 Tap(v3)
Frigidaire 56-2079-10-01 Tap(v1) / Microwave
Frigidaire 56-2080-10-01 Tap(v2) / Microwave
Frigidaire 56-2090-00-01 Tap(v2)
Frigidaire 56-2090-10-01 Tap(v1)
Frigidaire 56-2179-10-01 Tap(v1) / Microwave
Frigidaire 56-2180 MICROWAVE OVEN
Frigidaire 56-2180-00-01 Tap(v2) / Microwave
Frigidaire 56-2180-10-01 Tap(v1) / Microwave
Frigidaire 56-2243-10-01 Tap(v1) / .8 Microwave Oven
Frigidaire 56-2243-10-02 Tap(v2) / .8 Microwave Oven
Frigidaire 56-2243-10-03 Tap(v3) / .8 Microwave Oven
Frigidaire 56-2251-00-02 Tap(v2) / .8 Microwave Oven
Frigidaire 56-2251-10-01 Tap(v1) / .8 Microwave Oven
Frigidaire 56-2251-10-02 Tap(v1) / .8 Microwave Oven
Frigidaire 56-2251-10-03 Tap(v1) / .8 Microwave Oven
Frigidaire 56-2251-10-04 Tap(v2) / .8 Microwave Oven
Frigidaire 56-2258-10-01 Tap(v0) / Microwave Oven
Frigidaire 56-2258-10-15 Tap(v1) / Microwave
Frigidaire 56-2258-10-16 Tap(v2) / Microwave
Frigidaire 56-2259-10-16 Tap(v1) / Microwave
Frigidaire 56-2260-10-16 Tap(v1) / Microwave
Frigidaire 56-2268-00-01 Tap(v2) / Microwave
Frigidaire 56-2268-10-01 Tap(v1) / Microwave
Frigidaire 56-2268-10-15 Tap(v1) / Microwave
Frigidaire 56-2268-10-16 Tap(v2) / Microwave
Frigidaire 56-2271-10-01 Tap(v1) / .8 Microwave Oven
Frigidaire 56-2271-10-02 Tap(v1) / .8 Microwave Oven
Frigidaire 56-2272-10/01
Frigidaire 56-2272-10/02
Frigidaire 56-2277 TAPPAN MICROWAVE OVEN
Frigidaire 56-2277-10-01 Tap(v1)
Frigidaire 56-2277-23-01 Tap(v2)
Frigidaire 56-2278-10-01 Tap(v1) / Microwave Oven
Frigidaire 56-2278-10-02 Tap(v2) / Microwave Oven
Frigidaire 56-2278-10-03 Tap(v3) / Microwave Oven
Frigidaire 56-2278-10-15 Tap(v1) / Microwave
Frigidaire 56-2278-10-16 Tap(v2) / Microwave
Frigidaire 56-2280-10-16 Tap(v1) / Microwave
Frigidaire 56-2281-10/03
Frigidaire 56-2282-10-16 Tap(v2) / Microwave
Frigidaire 56-2287-10-01 Tap(v1) / Microwave
Frigidaire 56-2287-10-02 Tap(v2) / Microwave
Frigidaire 56-2288-10-01 Tap(v1)
Frigidaire 56-2288-10-02 Tap(v2)
Frigidaire 56-2359-10-01 Tap(v1) / Microwave
Frigidaire 56-2359-10-15 Tap(v1) / Microwave
Frigidaire 56-2359-10-16 Tap(v2) / Microwave
Frigidaire 56-2369-10-01 Tap(v1) / Microwave
Frigidaire 56-2369-10-15 Tap(v1) / Microwave
Frigidaire 56-2369-10-16 Tap(v2) / Microwave
Frigidaire 56-2451-10-01 Tap(v1) / Microwave
Frigidaire 56-2451-10-02 Tap(v2) / Microwave
Frigidaire 56-2451-10-03 Tap(v1) / .8 Microwave Oven
Frigidaire 56-2451-10-04 Tap(v2) / .8 Microwave Oven
Frigidaire 56-2461-10-01 Tap(v1) / Microwave
Frigidaire 56-2461-10-02 Tap(v1) / .8 Microwave Oven
Frigidaire 56-2461-10-03 Tap(v1) / .8 Microwave Oven
Frigidaire 56-2461-10-04 Tap(v2) / .8 Microwave Oven
Frigidaire 56-2461-10-05 Tap(v3) / .8 Microwave Oven
Frigidaire 56-2477 TAPPAN MICROWAVE OVEN
Frigidaire 56-2477-10-01 Tap(v3)
Frigidaire 56-2477-10-02 Tap(v1) / Microwave
Frigidaire 56-2477-10-03 Tap(v2) / Microwave
Frigidaire 56-2477-23-01 Tap(v4)
Frigidaire 56-2478-10-01 Tap(v1) / Microwave
Frigidaire 56-2651-10-01 Tap(v1) / .8 Microwave Oven
Frigidaire 56-2651-10-02 Tap(v2) / .8 Microwave Oven
Frigidaire 56-2651-10-03 Tap(v1) / .8 Microwave Oven
Frigidaire 56-2651-10-04 Tap(v2) / .8 Microwave Oven
Frigidaire 56-2661-00-01 Tap(v2) / .8 Microwave Oven
Frigidaire 56-2661-00-02 Tap(v4) / .8 Microwave Oven
Frigidaire 56-2661-10-01 Tap(v1) / .8 Microwave Oven
Frigidaire 56-2661-10-02 Tap(v3) / .8 Microwave Oven
Frigidaire 56-2661-10-03 Tap(v1) / .8 Microwave Oven
Frigidaire 56-2661-10-04 Tap(v1) / .8 Microwave Oven
Frigidaire 56-2661-10-05 Tap(v2) / .8 Microwave Oven
Frigidaire 56-2677-10-01 Tap(v1) / Microwave
Frigidaire 56-2678-10-01 Tap(v1) / Microwave Oven
Frigidaire 56-2678-10-02 Tap(v2) / Microwave Oven
Frigidaire 56-2678-10-15 Tap(v1) / Microwave
Frigidaire 56-2678-10-16 Tap(v2) / Microwave
Frigidaire 56-2690-10-16 Tap(v1) / Microwave
Frigidaire 56-2787-00-01 Tap(v2) / Microwave
Frigidaire 56-2787-00-02 Tap(v4) / Microwave
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
subzero 501f Shepard Oven Repair (including Ranges and Cooktops) 0 02-13-2012 10:45 PM
no ice- subzero 632 catatonic Refrigerator & Freezer Repair 0 10-12-2011 10:01 AM
Subzero 642 freezer compressor Vrr2536 Refrigerator & Freezer Repair 2 08-31-2011 06:33 AM
Subzero 642 cperinovic Refrigerator & Freezer Repair 1 07-30-2009 05:12 PM
Subzero freezeout Inspector 798 Refrigerator & Freezer Repair 3 11-06-2007 09:50 AM
