waschick
#1 Posted : Friday, April 12, 2013 5:08:29 AM(UTC)
waschick
The water dispenser continually freezes. The freezer temp control has been turned down to the lowest setting but the water line continues to freeze and in order to get it working the freezer door is left open for about an hour. I noticed that the food items in the freezer remain frozen solid even though the temp setting on the freezer is set at the lowest setting.
#2 Posted : Friday, April 12, 2013 2:21:32 PM(UTC)
If the temperature in the freezer is bellow 0°F, it can cause the water line inside the freezer door to freeze.
Unfortunately the freezer door in this refrigerator is no serviceable. If there is a problem with the temperature insulation inside the door, the whole door would need to be replaced.
Here are the breakdown diagrams and Parts for GE GSH25JSTASS Refrigerator - AppliancePartsPros.com
waschick
#3 Posted : Monday, April 15, 2013 11:07:53 AM(UTC)
waschick
Thanks!, I do not think it is an insulation problem. The temp control panel is set at the lowest setting for both refrig and freezer. I changed the thermistors in the freezer and it seemed to help but even at the "1" setting the freezer is (-2 )degrees and the refrig is 38 degrees. I cannot lower the temp any further on either side. No frost or ice in the freezer.
#4 Posted : Monday, April 15, 2013 11:37:03 AM(UTC)
Looks like there are two separate problems: freezing water line tube inside the freezer door and not adjustable temperatures.
The first problem is due to the freezer door temperature insulation.
The temperature problem is most likely due to faulty main control board on the back of the refrigerator.
- The main control board Part number: WR55X10942
