Discuss
GE Refrig - Compressor not turning on
 in
Refrigerator & Freezer Repair
The compressor (DC73C12RCU6) on my GE side-by-side (GS525SGRE) is not turning on. The fans are working, the light bulb turns
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE Refrig - Compressor not turning on
  #1 (permalink)
Old 04-07-2013, 08:57 AM
Junior Member
ddenuci is on a distinguished road
Default GE Refrig - Compressor not turning on
Brand: GE   Age: 5 - 10 years
The compressor (DC73C12RCU6) on my GE side-by-side (GS525SGRE) is not turning on. The fans are working, the light bulb turns on, etc.
First step was to unplug the refrig, and to remove the plastic cover on the left side of the compressor. Under this plastic cover were two components: a thermistor (Murata 6R8MD2) and a thermal protector (Klixon 4TM).
The thermistor (on some refrigerators, this component is a relay), is connected on one side to red and white wires. On the other side, the thermistor plugs into the "Start" and "Run" terminals of the compressor. The thermal protector connects to a black wire on one side, and to the third terminal on the compressor.
With the thermistor and thermal protector removed, I used a multimeter to measure the resistance between any two of the three terminals. The readings were : 4.6 ohms, 5.6 ohms, and 10.1 ohms. From what I've read, this indicates a good compressor, i.e., the larger value is roughly equal to the sum of the other two values. Also, I checked for shorts between any of the 3 terminals and the case of the compressor (after peeling away some of the paint), and there were not shorts.
Then, I set up the multimeter to measure AC voltage. I connected the leads to Red/Black, and plugged the refrig back in. The meter did not record any voltage. Did the same thing for White/Black, and again no voltage.
At this point, it seems that there is no reason to suspect that thermistor and thermal protector.
Questions:
1) Does this seem like a reasonable troubleshooting approach, given the symptoms?
2) What voltage should be measured across the White/Black leads, when everything is operational? I assume 115VAC. What about the Red/Black leads?
3) What controls the voltage to the compressor? Is it the digital circuit board inside the refrig?
4) Any other suggestions for next steps?
Thanks.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrig/Ice maker auger not turning pharmacist25 Refrigerator & Freezer Repair 10 03-12-2013 05:12 PM
Refrig ice maker's ice advance coil keeps turning by itself CarlEl Refrigerator & Freezer Repair 0 08-11-2011 11:48 AM
GE monogram refrig - ice maker auger motor not turning? Davedelta Refrigerator & Freezer Repair 6 08-30-2010 01:42 PM
Compressor not turning on goldenbear Refrigerator & Freezer Repair 6 03-24-2009 10:15 AM
HELP compressor is not turning on RIP Refrigerator & Freezer Repair 11 10-15-2008 02:08 PM
