Discuss
GE refrigerator/freezer not cooling
 in
Refrigerator & Freezer Repair
I have no idea what to test next (see recent repair history below). Since I replaced the evaporator fan motor,
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE refrigerator/freezer not cooling
  #1 (permalink)
Old 04-01-2013, 05:54 PM
Junior Member
dave27 is on a distinguished road
Default GE refrigerator/freezer not cooling
Model Number: Model TBX22ZKC   Brand: GE   Age: More than 10 years
I have no idea what to test next (see recent repair history below). Since I replaced the evaporator fan motor, the freezer was running 20 F, the refrigerator was fine. Saturday the freezer even went down to 10 F. This morning, 20 F/50 F. I defrosted the coils this evening. I again checked the defrost element ohms (28). I then checked for voltage to the defrost element, using a can of Freez-it to lower the temp of the defrost thermostat. At first I got 64 volts, then with a few more squirts 128 volts. There are two rows of coils in this unit, only the bottom row freezes up. Could there be a restriction in the line?
10/18/12: replace defrost thermostat (clips to coils). Tested bad in ice water bath
3/20/2013: clean condensor coils. Running hot due to apparent ice jam (defrost water found in bottom of refrigerator).
3/22/2013: defrost element reads 28.1 ohms. Replace defective evaporator fan motor (would only turn once you gave the blades a nudge).
3/29/13: replace defrost timer (old one tested good).
4/1/2013: unit not cooling (20 F/50 F). Defrost element reads 28.1 ohms. Appears to be getting voltage (see above).
Related Models
Whirlpool MODEL_PBK0190
Magic Chef MODW1A MWAVE- MOUNTED OVER RANGE/WO
Magic Chef MODW1V MWAVE- MOUNTED OVER RANGE/WO
Amana MP1.A COMMERCIAL MICROWAVES
Amana MP1.B COMMERCIAL MICROWAVES
Amana MPD218-02 MWAVE - FAMILY SIZE (60 HZ)
Frigidaire MPF200PBDA Frg(v2) / Gas Range
Frigidaire MPF200PBWA Frg(v1) / Gas Range
Frigidaire MPF240GSA GAS RANGE
Frigidaire MPF300BPDA Gib(v9) / Gas Range
Frigidaire MPF300PBDA Frg(v1) / Gas Range
Frigidaire MPF300PBDB Wwh(v1) / Gas Range
Frigidaire MPF300PBDC Frg(v1) / Gas Range
Frigidaire MPF300PBDD Frg(v1) / Gas Range
Frigidaire MPF300PBDE Frg(v1) / Gas Range
Frigidaire MPF300PBDF Frg(v1) / Gas Range
Frigidaire MPF300PBWA Frg(v2) / Gas Range
Frigidaire MPF300PBWB Wwh(v2) / Gas Range
Frigidaire MPF300PBWC Frg(v2) / Gas Range
Frigidaire MPF300PBWD Frg(v2) / Gas Range
Frigidaire MPF300PBWE Frg(v2) / Gas Range
Frigidaire MPF300PBWF Frg(v2) / Gas Range
Frigidaire MPF300PXWA Frg(v0) / Gas Range
Frigidaire MPF300PXWB Frg(v3) / Gas Range
Frigidaire MPF300PXWC Frg(v0) / Gas Range
Frigidaire MPF300PXWG Universal/gas Range
Frigidaire MPF300PXWH Universal/gas Range
Frigidaire MPF300PXWJ Universal/gas Range
Frigidaire MPF303PGDA Frg(v3) / Gas Range
Frigidaire MPF303PGDD Frg(v5) / Gas Range
Frigidaire MPF303PGDF Universal/gas Range
Frigidaire MPF303PGDG Universal/gas Range
Frigidaire MPF303PGDH Universal/gas Range
Frigidaire MPF303PGWA Frg(v4) / Gas Range
Frigidaire MPF303PGWC Frg(v6) / Gas Range
Frigidaire MPF303PGWD Frg(v7) / Gas Range
Frigidaire MPF303PGWF Universal/gas Range
Frigidaire MPF303PGWG Universal/gas Range
Frigidaire MPF303PGWH Universal/gas Range
Frigidaire MPF311PCDA Tap(v1) / Gas Range
Frigidaire MPF311PCWA Tap(v2) / Gas Range
Frigidaire MPF311PCWB Frg(v0) / Gas Range
Frigidaire MPF311PCWC Frg(v1) / Gas Range
Frigidaire MPF311PCWD Frg(v0) / Gas Range
Frigidaire MPF311PGWA Frg(v3) / Gas Range
Frigidaire MPF311PGWC Frg(v3) / Gas Range
Frigidaire MPF311PGWD Frg(v3) / Gas Range
Frigidaire MPF311PGWE Universal/gas Range
Frigidaire MPF311SBDA Frg(v3) / Gas Range
Frigidaire MPF311SBDB Frg(v1) / Gas Range
Frigidaire MPF311SBDC Frg(v2) / Gas Range
Frigidaire MPF311SBDD Frg(v1) / Gas Range
Frigidaire MPF311SBWA Frg(v4) / Gas Range
Frigidaire MPF311SBWB Frg(v2) / Gas Range
Frigidaire MPF311SBWC Frg(v3) / Gas Range
Frigidaire MPF311SBWD Frg(v2) / Gas Range
Frigidaire MPF311SGDA Frg(v4) / Gas Range
Frigidaire MPF311SGDC Frg(v4) / Gas Range
Frigidaire MPF311SGDD Frg(v4) / Gas Range
Frigidaire MPF311SGDE Universal/gas Range
Frigidaire MPF311SGWA Frg(v5) / Gas Range
Frigidaire MPF311SGWC Frg(v5) / Gas Range
Frigidaire MPF311SGWD Frg(v5) / Gas Range
Frigidaire MPF311SGWE Universal/gas Range
Frigidaire MPF500PBDA Frg(v4) / Gas Range
Frigidaire MPF500PBDB Frg(v1) / Gas Range
Frigidaire MPF500PBWA Frg(v3) / Gas Range
Frigidaire MPF500PBWB Frg(v2) / Gas Range
Amana MPP227 MWAVE- CNTRTP / STAND ALONE
Amana MPP228 MWAVE- CNTRTP / STAND ALONE
Amana MPP228100L MWAVE - FAMILY SIZE (60 HZ)
Amana MPR215 MWAVE- CNTRTP / STAND ALONE
Amana MPR21510 MWAVE- MOUNTED OVER RANGE/WO
Amana MPR217 MWAVE- CNTRTP / STAND ALONE
Amana MPR219 MWAVE- CNTRTP / STAND ALONE
Amana MPS218-10 RANGE- S/C S/I DDRAFT GAS
Amana MPS218-10 MWAVE- CNTRTP / STAND ALONE
Amana MPS219-10 RANGE- S/C S/I DDRAFT GAS
Amana MPS219-10 MWAVE- CNTRTP / STAND ALONE
Amana MPS225-10 MWAVE - FAMILY SIZE (60 HZ)
Amana MPS22510 MWAVE - FAMILY SIZE (60 HZ)
Amana MPS229-10 MWAVE - FAMILY SIZE (60 HZ)
Amana MPS22910 MWAVE - FAMILY SIZE (60 HZ)
Maytag MQC1557AEW FREEZER- VERTICAL
Maytag MQC1557BEW FREEZER- CHEST
Maytag MQC2257AEW FREEZER- CHEST
Maytag MQC2257BEW FREEZER- CHEST
Maytag MQU1554AEW FREEZER- VERTICAL
Maytag MQU1556AEW FREEZER- VERTICAL
Maytag MQU1654BEW FREEZER- VERTICAL
Maytag MQU1656BEW FREEZER- VERTICAL
Maytag MQU2056ARW FREEZER- VERTICAL
Maytag MQU2056BRW FREEZER- VERTICAL
Maytag MQU2056BRW03 VERTICAL FREEZER
Maytag MQU2057AEW FREEZER- VERTICAL
Maytag MQU2057BEW FREEZER- VERTICAL
Amana MR-1 RANGE- S/C S/I DDRAFT GAS
Amana MR-1W MWAVE - FAMILY SIZE (60 HZ)
Amana MR-2 RANGE- S/C S/I DDRAFT GAS
Amana MR-3 MWAVE - FAMILY SIZE (60 HZ)
 MR1031CWC MWAVE- CNTRTP / STAND ALONE
 MR1031UWC MWAVE- CNTRTP / STAND ALONE
 MR1031WB MWAVE- CNTRTP / STAND ALONE
 MR1032BB MWAVE- CNTRTP / STAND ALONE
 MR1032CBC MWAVE- CNTRTP / STAND ALONE
 MR1032UBC MWAVE- CNTRTP / STAND ALONE
 MR1033SB MWAVE- CNTRTP / STAND ALONE
 MR1034CBD MWAVE- CNTRTP / STAND ALONE
 MR1034CWD MWAVE- CNTRTP / STAND ALONE
 MR1034UBD MWAVE- CNTRTP / STAND ALONE
 MR1034UWD MWAVE- CNTRTP / STAND ALONE
 MR1351WB MWAVE- CNTRTP / STAND ALONE
  #2 (permalink)
Old 04-02-2013, 04:18 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
With only a few coils frozen, you have a refrigerant leak/bad compressor.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator/Freezer stops cooling, then starts cooling, then stops cooling angiebritt Refrigerator & Freezer Repair 4 05-16-2016 06:31 AM
Refrigerator and freezer not cooling slick154 Refrigerator & Freezer Repair 3 03-21-2013 11:56 AM
refrigerator/freezer not cooling charles powers Refrigerator & Freezer Repair 1 04-12-2010 07:45 PM
Freezer and Refrigerator not cooling as before Pinfish Refrigerator & Freezer Repair 5 07-05-2009 04:21 PM
no cooling in freezer or refrigerator Jerret Refrigerator & Freezer Repair 1 02-19-2009 07:52 AM
