Discuss
N'Finity wine refrigerator upper zone not cooling
 in
Refrigerator & Freezer Repair
I have an N'Finity by Wine Enthusiast dual zone wine refrigerator, that is 18 months old. The upper zone is
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » N'Finity wine refrigerator upper zone not cooling
  #1 (permalink)
Old 04-01-2013, 08:20 AM
Junior Member
kessency is on a distinguished road
Default N'Finity wine refrigerator upper zone not cooling
Model Number: 273 01 70   Brand: -other-   Age: 1 - 5 years
I have an N'Finity by Wine Enthusiast dual zone wine refrigerator, that is 18 months old. The upper zone is not holding the temperature, set point is set at 44 degrees, and lower zone is set at 60 degrees. The upper zone readout varies anywhere from 46 degrees to 52 degrees and sometimes (happened at least 3 times) goes to 58 to 60 degrees, while the lower zone stays very constant at 57 degrees to 60 degrees. I have measured the temperature inside the unit and the readings are very close to the readings on the readout on the control panel.
What is causing the upper zone to have the erratic readings? I will note that this refrigerator runs a lot (always has) and the compressor seems very warm to the touch, not hot hot.
Thanks for any help you can provide me. I am very handy with repairing things if you tell me what part is bad and how I can install it.
Related Models
Roper 2733*0A Ranges, Electric*
Roper 2733W0A Ranges, Electric*
Roper 2735*0A Ranges, Electric*
Jenn-Air 2750ELS WALLOVEN- STD ELE
Roper 2763*0A Ranges, Electric*
Roper 2763W0A Ranges, Electric*
Roper 2765*0A Ranges, Electric*
Roper 2765W0A Ranges, Electric*
Jenn-Air 2770ELD WALLOVEN- STD ELE
Jenn-Air 2775ELD WALLOVEN- STD ELE
Hoover 2800
Frigidaire 2803 GAS RANGE
Frigidaire 2803-80B GAS RANGE
Frigidaire 28044 FRIGIDAIRE GAS RANGE
Frigidaire 280440C GAS RANGE
Frigidaire 280447C GAS RANGE
Frigidaire 2809A GAS RANGE
Frigidaire 2811 GAS RANGE
Frigidaire 2812A GAS RANGE
Frigidaire 2813-80B GAS RANGE
Frigidaire 2813A GAS RANGE
Frigidaire 2819A GAS RANGE
Frigidaire 2820A GAS RANGE
Frigidaire 282240A GAS RANGE
Frigidaire 282240B GAS RANGE
Frigidaire 282240C GAS RANGE
Frigidaire 282247B GAS RANGE
Frigidaire 282247C GAS RANGE
Frigidaire 2822A GAS RANGE
Frigidaire 2823 GAS RANGE
Frigidaire 2823-80B GAS RANGE
Frigidaire 2828A GAS RANGE
Frigidaire 2829A GAS RANGE
Hoover 2830
Frigidaire 2833 GAS RANGE
Frigidaire 2833-80B GAS RANGE
Frigidaire 2834-80A GAS RANGE
Frigidaire 2834-80B FRIGIDAIRE GAS RANGE
Frigidaire 2834-87B FRIGIDAIRE GAS RANGE
Frigidaire 283440A GAS RANGE
Frigidaire 283440B GAS RANGE
Frigidaire 283440C FRIGIDAIRE GAS RANGE
Frigidaire 283440D GAS RANGE
Frigidaire 283447B GAS RANGE
Frigidaire 283447C FRIGIDAIRE GAS RANGE
Frigidaire 283447D GAS RANGE
Frigidaire 283460B GAS RANGE
Frigidaire 283460C GAS RANGE
Frigidaire 283467B GAS RANGE
Frigidaire 283467C GAS RANGE
Hoover 2836
Frigidaire 28364 GAS RANGE
Frigidaire 2841A GAS RANGE
Frigidaire 284260A GAS RANGE
Frigidaire 284267A GAS RANGE
Frigidaire 2843-80A GAS RANGE
Frigidaire 2843-80B GAS RANGE
Frigidaire 2843-80C GAS RANGE
Roper 2843W0A Ranges, Electric*
Frigidaire 284440A GAS RANGE
Frigidaire 284440B GAS RANGE
Frigidaire 284447A GAS RANGE
Frigidaire 284447B GAS RANGE
Frigidaire 2851A GAS RANGE
Frigidaire 2853 GAS RANGE
Frigidaire 28564 FRIGIDAIRE GAS RANGE
Frigidaire 285640A FRIGIDAIRE GAS RANGE
Frigidaire 285640B GAS RANGE
Frigidaire 285640D GAS RANGE
Frigidaire 285640E GAS RANGE
Frigidaire 285647A FRIGIDAIRE GAS RANGE
Frigidaire 285647B GAS RANGE
Frigidaire 285647D GAS RANGE
Frigidaire 285647E GAS RANGE
Frigidaire 285660A GAS RANGE
Frigidaire 285667A GAS RANGE
Frigidaire 28584 GAS RANGE
Frigidaire 285840A GAS RANGE
Frigidaire 285840B GAS RANGE
Frigidaire 285840C GAS RANGE
Frigidaire 285840D GAS RANGE
Frigidaire 285847A GAS RANGE
Frigidaire 285847B GAS RANGE
Frigidaire 285847C GAS RANGE
Frigidaire 285847D GAS RANGE
Frigidaire 28586 FRIGIDAIRE GAS RANGE
Frigidaire 285860A GAS RANGE
Frigidaire 285860B FRIGIDAIRE GAS RANGE
Frigidaire 285860C FRIGIDAIRE GAS RANGE
Frigidaire 285867A GAS RANGE
Frigidaire 28594 FRIGIDAIRE GAS RANGE
Frigidaire 285940A FRIGIDAIRE GAS RANGE
Frigidaire 285940B GAS RANGE
Frigidaire 285941A FRIGIDAIRE GAS RANGE
Frigidaire 285947A FRIGIDAIRE GAS RANGE
Frigidaire 285947B GAS RANGE
Frigidaire 2859A GAS RANGE
Frigidaire 2861A GAS RANGE
Frigidaire 2864 GAS RANGE
Frigidaire 2864-80B GAS RANGE
Frigidaire 2869A GAS RANGE
Frigidaire 2871A GAS RANGE
Roper 2872*0A Ranges, Electric*
Frigidaire 2872A GAS RANGE
Roper 2872W0A Ranges, Electric*
Frigidaire 2873 GAS RANGE
Frigidaire 2873B GAS RANGE
Frigidaire 2879A GAS RANGE
Frigidaire 2881 GAS RANGE
Frigidaire 2883 GAS RANGE
Roper 2883*10 Ranges, Electric*
Frigidaire 2883-80A GAS RANGE
Frigidaire 2883-81A GAS RANGE
Frigidaire 2883-81B GAS RANGE
Roper 2883W10 Ranges, Electric*
Frigidaire 2889A GAS RANGE
Frigidaire 2891 GAS RANGE
Frigidaire 2893 GAS RANGE
Roper 2893*0A Ranges, Electric*
Frigidaire 2893-80B GAS RANGE
  #2 (permalink)
Old 04-01-2013, 11:24 AM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Most likely the problem is with the upper zone thermistor, but also could be the control board.
We do not carry parts or any technical info for this brand. Contact the manufacturer.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 04-01-2013, 11:29 AM
Junior Member
Simon,
Thanks very much, I appreciate the help. I will contact Wine Enthusiast.
Keith
  #4 (permalink)
Old 04-01-2013, 11:38 AM
Expert
Default
You are welcome.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Magic Chef wine cooler - cooling/not cooling Skihartwell Refrigerator & Freezer Repair 0 01-20-2013 07:08 AM
Wine Cooler not cooling rlerner Refrigerator & Freezer Repair 1 05-24-2012 07:49 PM
Avanti Built in Dual Zone Wine Chiller banjosteve Refrigerator & Freezer Repair 0 02-19-2012 04:47 PM
GE side by side refrigerator - upper half not cooling and no ice cubes or water ngarey Refrigerator & Freezer Repair 0 09-13-2011 01:01 PM
K/A Wine Cooler not cooling warm wine Refrigerator & Freezer Repair 0 01-14-2009 11:02 AM
