my refrigerator and freezer get cold problem is freezer does not freeze put new defrost timer -checked compressor-evaporator fan-condensor fan-cleaned grids -checked coils-heat defroster-defrost thermastat-everything working --did not check cold control thermastat--could this be my problem i am not sure if the control thermastat has anything to do with the freezer to freeze--would appreciate some kind of help thank you very much jackdeecinto@comcast.net
