I replaced the motor in the back of the freezer last summer and the plastic fan blade is really loose and periodically slides off the end of the motor shaft. I've been using white plumbers tape inside the little hole of the fan blade to make the hole smaller.
Should I buy a new plastic fan blade or is there a way of tightening up the hole?
Hello,
What is the complete model number of the refrigerator?
What is the part number of the motor you installed?
