Here are a couple good sites with basic fridge repair help Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com http://www.applianceaid.com/refrigerator.htmlCheck the temperatures in the frezer and fresh foor with a thermometer. If they are OK then it is not a thermostat problem. Check that the compressor fan is running properly and that the condenser coils are clean. Open up the unit and take a look at the evaporator coil. Bets to do this about an hour or so after a defrost. Check the frost pattern on the coils if it is just in one area, usually where the freon enters the coil. Then you may have a low freon problem. |
THIS FORUM IS DEAD!!!!!!! |
