Hi--
I have replaced both the mother board and the temp indicator/control board. My temps are 0 for the freezer and 37 for the fridge.
My water flow was intermittent and now has not functioned for about 10 days.
What should i check next?
Thanks in advance for your help.
Joe
Groups: APP Team
Hi. Pull off the bottom grill and locate the connector on the water line going into the freezer door. Disconnect it on one side and with the door closed push the water lever at the dispenser. If the water comes from the tube - you have a frozen water line inside the freezer door. You will need to defrost the fridge and install the dispenser tube heater Part number: AP4318572
Hi Simon--
Well, I had my wife push the dispenser lever while I checked whether voltage was coming to the water valve, and the water started flowing. FIXED!
Thanks,
Joe
Groups: APP Team
That is a success story. Congratulations.
Simon.
P.S. It's got to be your wife's touch. :)
