Discuss
Side by side whirlpool frig ice/water dispenser, light not working
 in
Refrigerator & Freezer Repair
Checked plug at bottom of freezer door for power with meter. No power on plug feeding power to freezer door.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Side by side whirlpool frig ice/water dispenser, light not working
  #1 (permalink)
Old 03-07-2013, 06:16 AM
Junior Member
LenZ is on a distinguished road
Default Side by side whirlpool frig ice/water dispenser, light not working
Model Number: gd25bfchb00   Brand: Whirlpool   Age: 5 - 10 years
Checked plug at bottom of freezer door for power with meter. No power on plug feeding power to freezer door. connection and wires look OK. Does that wire harness go back to control board in back of fridge? If so, is there any fuses or anything to check on that? Thanks in advance for your help.
Ads By Google
Related Models
Whirlpool GD25BFCHB00
Whirlpool GD25BFCHB01
Whirlpool GD25BFCHT00
Whirlpool GD25BFCHT01
Whirlpool GD25BFCHW00
Whirlpool GD25BFCHW01
Whirlpool GD25DCXHS00
Whirlpool GD25DCXHS01
Whirlpool GD25DFXFB00
Whirlpool GD25DFXFB01
Whirlpool GD25DFXFB02
Whirlpool GD25DFXFB03
Whirlpool GD25DFXFN00
Whirlpool GD25DFXFN01
Whirlpool GD25DFXFN02
Whirlpool GD25DFXFN03
Whirlpool GD25DFXFT02
Whirlpool GD25DFXFT03
Whirlpool GD25DFXFW00
Whirlpool GD25DFXFW01
Whirlpool GD25DFXFW02
Whirlpool GD25DFXFW03
Whirlpool GD25DIXHB00
Whirlpool GD25DIXHB02
Whirlpool GD25DIXHS00
Whirlpool GD25DIXHS02
Whirlpool GD25DIXHT00
Whirlpool GD25DIXHT02
Whirlpool GD25DIXHW00
Whirlpool GD25DIXHW02
Whirlpool GD25DQXFB00
Whirlpool GD25DQXFB01
Whirlpool GD25DQXFN00
Whirlpool GD25DQXFN01
Whirlpool GD25DQXFW00
Whirlpool GD25DQXFW01
Whirlpool GD25FFCHB00 Refrigerator
Whirlpool GD25FFCHB01
Whirlpool GD25FFCHT00 Refrigerator
Whirlpool GD25FFCHT01
Whirlpool GD25FFCHW00 Refrigerator
Whirlpool GD25FFCHW01
Whirlpool GD25SFCHS10
Whirlpool GD25SFCHS11
Whirlpool GD25SFCHS111
Whirlpool GD25SFXHS00
Whirlpool GD25SFXHS01
Whirlpool GD25SFXHS02
Whirlpool GD25SFXHS03
Whirlpool GD25SFXHS04
Whirlpool GD25SFXHS05
Whirlpool GD25SHAXLB01
Whirlpool GD25SHAXLQ01
Whirlpool GD25SHAXLT01
Whirlpool GD25SSFCHS10
Whirlpool GD27DFXFB00
Whirlpool GD27DFXFB01
Whirlpool GD27DFXFB02
Whirlpool GD27DFXFB03
Whirlpool GD27DFXFN00
Whirlpool GD27DFXFN01
Whirlpool GD27DFXFN02
Whirlpool GD27DFXFN03
Whirlpool GD27DFXFT02
Whirlpool GD27DFXFT03
Whirlpool GD27DFXFW00
Whirlpool GD27DFXFW01
Whirlpool GD27DFXFW02
Whirlpool GD27DFXFW03
Whirlpool GD27DIXHB00
Whirlpool GD27DIXHB01
Whirlpool GD27DIXHB02
Whirlpool GD27DIXHS00
Whirlpool GD27DIXHS01
Whirlpool GD27DIXHS02
Whirlpool GD27DIXHT00
Whirlpool GD27DIXHT01
Whirlpool GD27DIXHT02
Whirlpool GD27DIXHW00
Whirlpool GD27DIXHW01
Whirlpool GD27DIXHW02
Whirlpool GD27DQXFB00
Whirlpool GD27DQXFB01
Whirlpool GD27DQXFN00
Whirlpool GD27DQXFN01
Whirlpool GD27DQXFW00
Whirlpool GD27DQXFW01
Whirlpool GD2LHGXKB00
Whirlpool GD2LHGXKQ00
Whirlpool GD2LHGXKT00
Whirlpool GD2LHGXLB00
Whirlpool GD2LHGXLB01
Whirlpool GD2LHGXLB03
Whirlpool GD2LHGXLB04
Whirlpool GD2LHGXLQ00
Whirlpool GD2LHGXLQ01
Whirlpool GD2LHGXLQ03
Whirlpool GD2LHGXLQ04
Whirlpool GD2LHGXLT00
Whirlpool GD2LHGXLT01
Whirlpool GD2LHGXLT03
Whirlpool GD2LHGXLT04
Whirlpool GD2NHAXMB00 Refrigerator
Whirlpool GD2NHAXMQ00 Refrigerator
Whirlpool GD2NHAXMT00 Refrigerator
Whirlpool GD2NHGXKB01
Whirlpool GD2NHGXKB02
Whirlpool GD2NHGXKQ01
Whirlpool GD2NHGXKQ02
Whirlpool GD2NHGXKT01
Whirlpool GD2NHGXKT02
Whirlpool GD2NHGXLQ00
Whirlpool GD2NHGXLT00
Whirlpool GD2SHAXKB01
Whirlpool GD2SHAXKB02
Whirlpool GD2SHAXKB03
Whirlpool GD2SHAXKQ01
Whirlpool GD2SHAXKQ02
Whirlpool GD2SHAXKQ03
Whirlpool GD2SHAXKT01
  #2 (permalink)
Old 03-07-2013, 06:38 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
LenZ, No, there are no fuses or anything to check on. The black wire in the freezer door harness, is a direct connection to the power cord, the control board is not involved in the dispenser operation of your refrigerator. You'll need to check the black wire from the door hinge back to the power cord, until you find the loose connection or broken wire.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 03-07-2013, 06:41 AM
Junior Member
Default
Quote:
Joe, thanks for the information. I will check this evening..
  #4 (permalink)
Old 03-07-2013, 08:26 AM
Senior Expert
Default
OK, Please remember to post your results. So other readers can refer to your experience and repair.
Thanks,
__________________
Joe M. APP TEAM
  #5 (permalink)
Old 03-07-2013, 06:36 PM
Junior Member
Default
Thanks,
Joe,
Looks like I didn't have a good ground for my meter. I have 120VAC on the blue wire with a black stripe. I pulled the front dispenser panel and I don't have 120VAC on the same blue/black stripe wire there or any voltage past .3VAC. I pulled the door switch and it ohms out fine. I tried seeing if the plug below the freezer door has continuity to the plug on the dispenser panel (e.g. ohmed out the blue wire with black strip on both ends of the connectors). Does the wire harness go from the bottom of the freezer door to the front panel? If so, it appears the wire is broken? Any next suggestions, thanks in advance for your help.
  #6 (permalink)
Old 03-08-2013, 06:41 AM
Senior Expert
Default
Joe,
LenZ,
There's nothing easy with this type issue. Yes the blue/black wire is the 120 VAC circuit to the dispenser switches, etc. It attaches to the freezer door light switch, routes through the cabinet, and does exit at the door hinge. Then is routed from the hinge to the dispenser through the door panel. If you're lucky, when you remove the freezer door, you'll find that the blue/black wire is loose in the connector or frayed/broken at the connector and door hinge opening in the bottom of the door, and may be repairable.
__________________
Joe M. APP TEAM
  #7 (permalink)
Old 03-11-2013, 08:50 AM
Junior Member
Default
LenZ,
Cut the black mesh protecting the wires leading into the freezer door and 3 of the wires were broken (due to opening and closing door). I soldered the wires together and ice/water dispenser working fine. Thanks for your help!!
  #8 (permalink)
Old 03-11-2013, 09:02 AM
Senior Expert
Default
LenZ,
Great,
Glad we were able to help you out.
Thanks for the update.
Good Luck,
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Side-by-side Water Dispenser Not working rick matejka Refrigerator & Freezer Repair 4 04-17-2012 10:54 AM
Side by side whirlpool frig ice/water dispenser, light not working NDOGO Refrigerator & Freezer Repair 5 04-15-2012 07:21 PM
Whirlpool Side by side ice dispenser stopped working mariadragani@verizon.net Refrigerator & Freezer Repair 0 10-19-2011 11:34 AM
Frigidaire Side by Side Water dispenser not working eckzlnt Refrigerator & Freezer Repair 0 07-06-2010 06:09 PM
Amana Side by Side Water and Ice Dispenser stopped working RBrrttJr Refrigerator & Freezer Repair 0 01-27-2010 12:03 PM
