| » What Part Do I Need??? |
Model Number: HSM25GFTSA Brand: Hotpoint Age: 1 - 5 years
OK. It's a Hotpoint Side by side.
-Makes and dispenses ice. -DOES NOT dispense water. -DOES NOT have water at bottom of door coupler. -CAN NOT determine from schematic which part I need tp check or replace. Is it on back of fridge behind FILTER connection? OR is on the water line that crosses from filter connection to bottom right corner on back? Thanks. Ads By Google Related Models |
Quote:
Part number: AP3192626 But you do want to check, or replace the water filter Part number: AP3859302 If you haven't replaced it in the last 6 to 12 months, It could be clogged/filled with debris.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Thanks. That is very helpful! But where exactly is that little dude located?
Already replaced the filter but if that were clogged, it wouldn't make ice would it? Last edited by got2git1 : 03-07-2013 at 06:39 PM. Reason: additional info |
Quote:
The water inlet valve Part number: AP3192626 Is located on the back of the refrigerator. You'll need to slide the refrigerator away from the wall, unplug the power cord and turn off the water supply. It's a lot easier if you remove the compressor compartment (cardboard) cover. Just remember to label the wires and tubes before you disconnect them, or switch components, one at a time. It's easier on you to work that way.
__________________
| Display Modes | |
| Replacement part for discontinued part #9741559 | James F Morin | Dishwasher Repair | 2 | 06-03-2009 12:06 PM |
| Part for GE dishwasher is different from existing part | kevinpvb | Dishwasher Repair | 0 | 06-03-2009 12:04 PM |
| Replacement part for discontinued part | titans33 | Oven Repair (including Ranges and Cooktops) | 0 | 05-27-2009 04:40 PM |
| Need discontinued part for Jenn-Air range. Part #74002173 Clock component | Sandi Gainey | Oven Repair (including Ranges and Cooktops) | 0 | 03-25-2009 05:33 PM |
| Freezer part cold, fridge part warm | keithpar | Refrigerator & Freezer Repair | 1 | 10-08-2007 03:21 AM |
