| » refrigerator |
Model Number: et22dkxfn00 Brand: Whirlpool Age: More than 10 years
freezer and refrigerator get cold but freezer does not freeze and refrigerator runs constantly
Here are your parts.
Parts for Whirlpool ET22DKXFN00 Refrigerator - AppliancePartsPros.com Check to be sure that the compressor is running. You can usually hear it but you should also be able to feel it vibrating and it should be warm. Check that the condenser/compressor fan is running and that the condenser coils are clean. Check that the evaporator/freezer fan is running. If all OK remove the cover in the freezer so that you can inspect the evaporator coils. If they are heavily frosted/iced over you have a defrost problem. Should be repairable at a fairly reasonable cost. If there is no frost or just frost in one area (usually where the freon enters the coils) you have a sealed system problem. Be sure to check it after the compressor has run for a couple hours. If you check it shortly after a defrost cycle you will come up with the wrong conclusion. This will be an expensive repair as you need a pro. Often it makes more sense to put the dollars towards a new unit. Here is a good link check out the example pictures, about half way down the page. http://www.applianceaid.com/refriger...old-enough.php Check the unit's warranty often the sealed system has a longer warranty.
__________________
- Last edited by denman : 03-07-2013 at 03:08 AM. |
| Display Modes | |
| Magic Chef Refrigerator Freezer work Refrigerator not cold enough | tg06222 | Refrigerator & Freezer Repair | 1 | 09-05-2011 03:56 AM |
| Admiral refrigerator/top freezer not defrosting, and refrigerator getting warm | 808BigShorty | Refrigerator & Freezer Repair | 2 | 02-23-2011 01:04 PM |
| refrigerator making loud revving engine noise and now feels warm in refrigerator part | tallulah | Refrigerator & Freezer Repair | 0 | 02-06-2011 07:15 AM |
| Moved refrigerator, freezer fine but refrigerator is too warm | tigerjim | Refrigerator & Freezer Repair | 1 | 06-09-2010 10:59 AM |
