Discuss
Freezer is Very frosty!
 in
Refrigerator & Freezer Repair
Twice in the past year the Top mounted freezer on my Whirlpool would drain water to the bottom of the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer is Very frosty!
  #1 (permalink)
Old 03-06-2013, 01:43 PM
Junior Member
Tigerpaw is on a distinguished road
Default Freezer is Very frosty!
Brand: Whirlpool   Age: 5 - 10 years
Twice in the past year the Top mounted freezer on my Whirlpool would drain water to the bottom of the refrigerator. I cleaned the freezer and made sure the drain hose was clear.
- Now the freezer looks as though there was a snow storm in it. Everything is frosty! Yes, there's water draining into the bottom of the refrigerator again.
I'm not a refrigeration technician though I'd like to fix this myself. Any ideas on what I can do, or shall I call a repair-person and bite the bullet?
Thanks in advance for any help
Ads By Google
  #2 (permalink)
Old 03-06-2013, 03:28 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Dear Tigerpaw.
It will help a lot if you'll post the model number of the fridge.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 03-06-2013, 03:41 PM
Junior Member
Default Response:
Hello:
My refrigerator is a Whirlpool model: ET1CHNXKQ00 or it is model: ETICHMXKQOO.
The difference in model number may be the second figure either a 1 or the letter i.
  #4 (permalink)
Old 03-06-2013, 05:34 PM
Expert
Default
Hi.
Regarding the frost in the freezer.
Check the freezer temperature it shouldn't be much below 0 F*.Adjust if needed. Make sure the door gasket is intact, the frequent opening of the door may cause the frosting. Some produce left in the freezer for long time will frost up eventually.
Regarding the drain.
Defrost and clean the drain, pour hot water in it to make sure it's open, then install the drain heater kit Part number: 819043
Part number: 819043
That should help.
Simon.
__________________
  #5 (permalink)
Old 03-07-2013, 02:25 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Could also be large temperature swings in the freezer.
Put a bowl of ice cubes in the freezer.
Leave it for a day or so.
If they end up all frozen solid together then the freezer is getting too warm.
Stuff is melting creating water vapor which then condenses on the freezer walls when it re-freezes.
Can be caused by a bad main control thermostat.
Or by the defrost thermostat not shutting off the defrost heater when all the frost has been removed from the evaporator coils.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice maker and frosty freezer craig83 Refrigerator & Freezer Repair 1 10-04-2012 04:38 PM
Frosty Freezer mdmattos Refrigerator & Freezer Repair 0 08-12-2011 12:42 AM
Frosty coils sputnik Refrigerator & Freezer Repair 1 07-14-2011 04:10 PM
Frosty Freezer not so cold fridge rosalozaw Refrigerator & Freezer Repair 0 12-22-2009 08:24 AM
Freezer thaws out ,then ices up very frosty Perry Greene Refrigerator & Freezer Repair 1 06-30-2009 06:16 PM
