| » Help Amercana Trippig Off |
Model Number: A3316ABSHRBC Brand: -other- Age: Less than 1 year
Help I Have A Amercana Refridge Plug In Compreeser Comes On Fan Comes On Sfeel Cold Air In Refridge Will Run For About 1 Hour Comp Stop Fan Stop Will Not Come Back On Unless You Unplug For A Little Awhile Then Will Start Rght Back Up For About Hour Or So Please Help
Parts for A3316ABSHRBC - AppliancePartsPros.com You unit does not come up but the listed units should be close. The unit is made by GE. Have you tried moving the temperature knob back and forth to see if it will start up. Since it is GE I will not be able to get a wiring diagram for it. But most older fridges have the compressor and the condenser/compressor fan wired in parallel. Since they are both going off the most likely culprit is the temperature thermostst as the controls power to the compressor/fan.
__________________
| Display Modes | |
