Discuss
kenmore water dispenser slow
 in
Refrigerator & Freezer Repair
So we bought a Kenmore Coldspot side by side fridge model number 10656346500 and the guy said that there was
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » kenmore water dispenser slow
  #1 (permalink)
Old 03-03-2013, 07:42 PM
Junior Member
scmb is on a distinguished road
Default kenmore water dispenser slow
Model Number: 10656346500   Brand: Kenmore   Age: 5 - 10 years
So we bought a Kenmore Coldspot side by side fridge model number 10656346500 and the guy said that there was a problem with the ice maker. when we finally got around to plumbing the water line we replace the filter and the water in the dispener comes out really slowly. the ice dispenser leaks water out the front ice dispenser also. So I started searching around on the internet. I started by changing the water valve. No change. I changed the water filter housing and no change. I have good pressure coming in the back, the inlet t valve is open all the way. I have run the water dispenser without the filter but I dont have a bypass to put in there(not sure what it is exactly), however the water flows good from the dispenser without the filter. With the filter in I disconnected the water tube running from the water valve, then up the door to the water dispenser and it is trickling out of that as well. After you try to run the water, there is a noise in the back upper area of the fridge that sounds similar to chewbacca noise minus the growl at the end. I have soaked the filter overnight also and it did get rid of the first noise we were hearing that sounded like air in the front lines that was audible while dispensing the water not after like the chewbacca noise. I read about purging the lines to get rid of sediment build up but we replaced the valve and the filter housing. anybody know of another part that i can throw on to see if it works? Any ideas? Any ideas for thawing the ice cubes out without making a total mess.I would like it if we could get the ice and the water working. thanks in advance for any help. Let me know if you need more info or if I confused you.
Related Models
Kenmore 10656346500 SIDE-BY-SIDE
Kenmore 10656349500 SIDE-BY-SIDE
Kenmore 10656352500 SIDE-BY-SIDE
Kenmore 10656354500 SIDE-BY-SIDE
Kenmore 10656356500 SIDE-BY-SIDE
Kenmore 10656359500 SIDE-BY-SIDE
Kenmore 10656362400 REFRIGERATOR, SXS
Kenmore 10656363400 REFRIGERATOR, SXS
Kenmore 10656364400 REFRIGERATOR, SXS
Kenmore 10656366400 REFRIGERATOR, SXS
Kenmore 10656369400 REFRIGERATOR, SXS
Kenmore 10656372400 REFRIGERATOR, SXS
Kenmore 10656373400 REFRIGERATOR, SXS
Kenmore 10656374400 REFRIGERATOR, SXS
Kenmore 10656376400 REFRIGERATOR, SXS
Kenmore 10656379400 REFRIGERATOR, SXS
Kenmore 10656382500 SIDE BY SIDE REFRIGERATOR
Kenmore 10656382501 SIDE BY SIDE REFRIGERATOR
Kenmore 10656383500 SIDE BY SIDE REFRIGERATOR
Kenmore 10656383501 SIDE BY SIDE REFRIGERATOR
Kenmore 10656384500 SIDE BY SIDE REFRIGERATOR
Kenmore 10656384501 SIDE BY SIDE REFRIGERATOR
Kenmore 10656386500 SIDE BY SIDE REFRIGERATOR
Kenmore 10656386501 SIDE BY SIDE REFRIGERATOR
Kenmore 10656389500 SIDE BY SIDE REFRIGERATOR
Kenmore 10656389501 SIDE BY SIDE REFRIGERATOR
Kenmore 10656392501 SIDE BY SIDE REFRIGERATOR
Kenmore 10656393501 SIDE BY SIDE REFRIGERATOR
Kenmore 10656394501 SIDE BY SIDE REFRIGERATOR
Kenmore 10656396501 SIDE BY SIDE REFRIGERATOR
Kenmore 10656399501 SIDE BY SIDE REFRIGERATOR
Kenmore 1065645180 COLDSPOT DEHUMIDIFIER
Kenmore 1065649190 COLDSPOT DEHUMIDIFIER
Kenmore 10656502400 SIDE BY SIDE REFRIGERATOR
Kenmore 10656532400 REFRIGERATOR, SXS
Kenmore 10656533400 REFRIGERATOR, SXS
Kenmore 10656534400 REFRIGERATOR, SXS
Kenmore 10656536400 REFRIGERATOR, SXS
Kenmore 10656536401 SIDE BY SIDE REFRIGERATOR
Kenmore 10656539400 REFRIGERATOR, SXS
Kenmore 10656542400 REFRIGERATOR, SXS
Kenmore 10656543400 REFRIGERATOR, SXS
Kenmore 10656544400 REFRIGERATOR, SXS
Kenmore 10656546400 REFRIGERATOR, SXS
Kenmore 10656546401 SIDE BY SIDE REFRIGERATOR
Kenmore 10656549400 REFRIGERATOR, SXS
Kenmore 10656562400 REFRIGERATOR SXS
Kenmore 10656563400 REFRIGERATOR SXS
Kenmore 10656564400 REFRIGERATOR SXS
Kenmore 10656566400 REFRIGERATOR SXS
Kenmore 10656569400 REFRIGERATOR SXS
Kenmore 10656572400 REFRIGERATOR SXS
Kenmore 10656573400 REFRIGERATOR SXS
Kenmore 10656574400 REFRIGERATOR SXS
Kenmore 10656576400 REFRIGERATOR SXS
Kenmore 10656579400 REFRIGERATOR SXS
Kenmore 10656582500 SXS
Kenmore 10656584500 REFRIGERATOR
Kenmore 10656586500 SXS
Kenmore 10656586501 SIDE BY SIDE REFRIGERATOR
Kenmore 10656589500 SXS
Kenmore 10656592500 SXS
Kenmore 10656594500 REFRIGERATOR
Kenmore 10656596500 REFRIGERATOR
Kenmore 10656596501 SIDE BY SIDE REFRIGERATOR
Kenmore 10656599500 REFRIGERATOR
Kenmore 10656612500 SXS
Kenmore 10656619500 SIDE BY SIDE REFRIGERATOR
Kenmore 10656622500 SXS
Kenmore 10656629500 SIDE BY SIDE REFRIGERATOR
Kenmore 10656642500 SIDE-BY-SIDE
Kenmore 10656644500 SIDE-BY-SIDE
Kenmore 10656646500 SIDE-BY-SIDE
Kenmore 10656649500 SIDE-BY-SIDE
Kenmore 10656652500 SIDE-BY-SIDE
Kenmore 10656654500 SIDE-BY-SIDE
Kenmore 10656656500 SIDE-BY-SIDE
Kenmore 10656659500 SIDE-BY-SIDE
Kenmore 10656662500 REFRIGERATOR
Kenmore 10656662502 SIDE BY SIDE REFRIGERATOR
Kenmore 10656663500 REFRIGERATOR
Kenmore 10656663502 SIDE BY SIDE REFRIGERATOR
Kenmore 10656664500 REFRIGERATOR
Kenmore 10656664502 SIDE BY SIDE REFRIGERATOR
Kenmore 10656666500 REFRIGERATOR
Kenmore 10656666501 SIDE BY SIDE REFRIGERATOR
Kenmore 10656666502 SIDE BY SIDE REFRIGERATOR
Kenmore 10656669500 REFRIGERATOR
Kenmore 10656669502 SIDE BY SIDE REFRIGERATOR
Kenmore 10656672500 SIDE BY SIDE REFRIGERATOR
Kenmore 10656672502 SIDE BY SIDE REFRIGERATOR
Kenmore 10656673500 SIDE BY SIDE REFRIGERATOR
Kenmore 10656673502 SIDE BY SIDE REFRIGERATOR
Kenmore 10656674500 SIDE BY SIDE REFRIGERATOR
Kenmore 10656674502 SIDE BY SIDE REFRIGERATOR
Kenmore 10656676500 SIDE BY SIDE REFRIGERATOR
Kenmore 10656676501 SIDE BY SIDE REFRIGERATOR
Kenmore 10656676502 SIDE BY SIDE REFRIGERATOR
Kenmore 10656679500 SIDE BY SIDE REFRIGERATOR
Kenmore 10656679502 SIDE BY SIDE REFRIGERATOR
Kenmore 10656682500 REFRIGERATOR
Kenmore 10656682501 SIDE BY SIDE REFRIGERATOR
Kenmore 10656682502 SIDE BY SIDE REFRIGERATOR
Kenmore 10656683500 REFRIGERATOR
Kenmore 10656683501 SIDE BY SIDE REFRIGERATOR
Kenmore 10656683502 SIDE BY SIDE REFRIGERATOR
Kenmore 10656684500 REFRIGERATOR
Kenmore 10656684501 SIDE BY SIDE REFRIGERATOR
Kenmore 10656684502 SIDE BY SIDE REFRIGERATOR
Kenmore 10656686500 REFRIGERATOR
Kenmore 10656686501 SIDE BY SIDE REFRIGERATOR
Kenmore 10656686502 SIDE BY SIDE REFRIGERATOR
Kenmore 10656689500 REFRIGERATOR
Kenmore 10656689501 SIDE BY SIDE REFRIGERATOR
Kenmore 10656689502 SIDE BY SIDE REFRIGERATOR
Kenmore 10656692501 SIDE BY SIDE REFRIGERATOR
Kenmore 10656692502 SIDE BY SIDE REFRIGERATOR
Kenmore 10656693501 SIDE BY SIDE REFRIGERATOR
Kenmore 10656693502 SIDE BY SIDE REFRIGERATOR
Kenmore 10656694501 SIDE BY SIDE REFRIGERATOR
  #2 (permalink)
Old 03-04-2013, 06:57 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
You have to flush the water system after you replaced the water filter to get rid of air in the system. You can find the instructions in one of our previous threads: Water dispenser leak!!!
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 03-05-2013, 12:18 AM
Junior Member
Default
Cool thanks for the reply. I tried what you said. I did it for about 10 minutes and only got about 1/2 gallon. I found a youtube video that said to do it for 2 minutes. When I first hooked up the new filter, it coughed and sputtered air out the first couple times I tried. Now doing what you said, it is only putting out water, there is no air sputtering out. Do you still think I need to bleed it or maybe something else is wrong? the generic filter I got off of Amazon had mixed reviews, but nobody said it didnt work. I guess a couple of them blew up in the fridge flooding the kitchen. thanks for the help
-Jesse
  #4 (permalink)
Old 03-05-2013, 12:15 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Jesse,
What is the part number of the filter you installed?
__________________
  #5 (permalink)
Old 03-05-2013, 04:13 PM
Junior Member
Default
The part number is WSW-1 and it is made by Water Sentinel
  #6 (permalink)
Old 03-06-2013, 03:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I understand your point. Everyone would like to save money wherever it's possible. The original water filter for this refrigerator is Part number: 4396510
I've checked all available information and I did not find any reliable references for this aftermarket filter you used. That could be the culprit.
I would recommend to order the original filter and give it a try. You may want to order it from APP because in such case you can return the part if it would not work.
__________________
  #7 (permalink)
Old 03-06-2013, 08:51 PM
Junior Member
Default
Hey Gene thank you very much for all your help. My wife was in charge of ordering the filter and that was the only one she found apparently. Ill give that filter a try and if that doesn't work then I guess I will have to resort to an inline filter with the bypass in permanently. Thanks again its pretty amazing that people like you with the knowledge are willing to take your personal time to help out all of the people on here
  #8 (permalink)
Old 03-07-2013, 12:51 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. Thank you for good words. Good luck and keep us posted.
__________________
  #9 (permalink)
Old 06-01-2013, 07:55 AM
Junior Member
Default
hey I just wanted to follow up on my problem. I changed the filter to the one you mentioned Gene and it seemed to get a little faster but not much. I've been monitoring it and waiting to see if it sped up at all. It really hasn't much. It takes about 40 second to fill up a pint glass to the brim but it is fast enough I suppose. Would be nice if it was faster. Anybody know how long it takes for the average water dispenser to dispense a pint of water?
  #10 (permalink)
Old 03-10-2015, 03:02 PM
Junior Member
Robrepair21 is on a distinguished road
Default Did you get an answer?
I am having the exact same trouble with my Kenmore water dispenser. Did you ever get a solution to your problem? If so could you please share?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Slow Water Dispenser seebok Refrigerator & Freezer Repair 35 02-22-2014 08:50 AM
Kenmore slow flow water dispenser roadiega Refrigerator & Freezer Repair 0 01-13-2012 07:05 PM
Amana Water Dispenser slow qglasspa Refrigerator & Freezer Repair 1 03-01-2011 11:31 AM
Water Dispenser Slow Ed60062 Refrigerator & Freezer Repair 8 12-17-2010 10:29 PM
Slow Water Dispenser scomaral Refrigerator & Freezer Repair 0 06-27-2009 06:10 PM
