Discuss
Is the heater part of the control board?
 in
Refrigerator & Freezer Repair
To test for continuity on the older combination bimetal thermostat/ defrost temperature sensor, which is what I have on my
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Is the heater part of the control board?
  #1 (permalink)
Old 03-03-2013, 01:57 PM
Junior Member
pondfrog321 is on a distinguished road
Post Is the timer part of the main control board?
Model Number: RS2533SW/XAA   Brand: Samsung   Age: 5 - 10 years
To test for continuity on the older combination bimetal thermostat/ defrost temperature sensor, which is what I have on my 2003 Samsung RS2533SW/XAA model, do you have to submerge the thermostat in ice water to get a closed circuit reading? No one has bothered to answer my other question yet. I unplugged the refrigerator for 7 hours and when I took a reading for continuity on my combination bimetal thermostat/defrost temp. sensor connector, it showed an open circuit. When I plugged the refrig back in and took a reading two hours later, my multimeter beeped on the continuity setting, indicating a closed circuit although I couldn't get an ohm reading. It showed 0.L on the display readout. I have a very complex Fluke meter and I'm wondering if I have to reset the range to get an accurate ohms reading. Also, is the timer actually part of the main control board in this model and how do I check it. The timer controls what? Does it control how long the drain heater is on or how long the thermostat stays closed or something else? One other thing I need to clarify, since Samsung has had so many issues with its units icing up, the company has re-engineered or modified their heater components and evaporator systems several times over. My 2003 model has only one heater at the bottom of the evaporator assembly called a drain heater. I do not have an additional heater woven into the evaporator assembly. That design change was done after my 2003 model was manufactured. Also, my bimetal thermostat & defrost temperature sensor were wired into the same connector plug. Samsung has changed the design of those dual components after my 2003 model, as well. Now these are sold as two separate components each with its own connector plug, which I can't use since I have only one female connector plug for both. When I was researching the icing problem in my freezer, I checked my drain heater for continuity. I had to replace it. Then I checked the combi thermostat/ defrost sensor and had the two readings described above. Now I want to check the timer to see if it is defrosting the evaporator coils for a long enough time period. I'm not sure how long it's supposed to stay on or send a current but I was told by a technician that even if your thermostat, defrost sensor, and heater are working, the timer may not be keeping one of these components heating or closed long enough. Since I'm no certain which of these components is being controlled by the timer, I'd like to know the answer to that question, as stated before. So, how do I check the timer if it is integrated in the control board, as opposed to an actual timer that can be replaced? I see that there are pins to check readings on the control board but I do not know how to check the readings, although I have a key to read the PCB layout on the control board. This diagnosis may be beyond my scope.
Ads By Google
Related Models
 RS2533VK REF - SXS
 RS2533VQ REF - SXS
 RS2534BB REF - SXS
 RS2534VQ REF - SXS
 RS2534WW REF - SXS
 RS253BABB REF - SXS
 RS253BASB REF - SXS
 RS253BAVQ REF - SXS
 RS253BAWW REF - SXS
 RS2544SL REF - SXS
 RS2545SH REF - SXS
 RS2555BB REF - SXS
 RS2555SL REF - SXS
 RS2555SW REF - SXS
 RS2556BB REF - SXS
 RS2556SH REF - SXS
 RS2556WW REF - SXS
 RS255BABB REF - SXS
 RS255BASB REF - SXS
 RS255BAWW REF - SXS
 RS2577BB REF - SXS
 RS2577SL REF - SXS
 RS2577SW REF - SXS
 RS2578BB REF - SXS
 RS2578SH REF - SXS
 RS2578WW REF - SXS
 RS257BARB REF - SXS
Frigidaire RS259ESD1 Wwh(v1) / Side By Side Refrigerator
Frigidaire RS259ESD2 Wwh(v2) / Side By Side Refrigerator
Frigidaire RS259ESF1 Wwh(v3) / Side By Side Refrigerator
Frigidaire RS259ESF2 Wwh(v4) / Side By Side Refrigerator
Frigidaire RS259ESH1 Wwh(v5) / Side By Side Refrigerator
Frigidaire RS259ESH2 Wwh(v6) / Side By Side Refrigerator
Frigidaire RS259ESV1 Wwh(v7) / Side By Side Refrigerator
Frigidaire RS259ESV2 Wwh(v8) / Side By Side Refrigerator
Frigidaire RS259ESW1 Wwh(v9) / Side By Side Refrigerator
Frigidaire RS259ESW2 Wwh(v10) / Side By Side Refrigerator
Roper RS25AEXLQ00 REFRIGERATOR
Roper RS25AFXMQ00 REFRIGERATOR
Roper RS25AFXRD01 REFRIGERATOR
Roper RS25AFXRD02 REFRIGERATOR
Roper RS25AGXNQ00 REFRIGERATOR
Roper RS25AGXNQ01 REFRIGERATOR
Roper RS25AGXNQ02 REFRIGERATOR
Roper RS25AQXFN00 REFRIGERATOR
Roper RS25AQXFN01 REFRIGERATORS
Roper RS25AQXFN02 REFRIGERATOR
Roper RS25AQXFW00 REFRIGERATOR
Roper RS25AQXFW01 REFRIGERATORS
Roper RS25AQXFW02 REFRIGERATOR
Roper RS25AQXGN00 REFRIGERATOR
Roper RS25AQXGN01 REFRIGERATOR
Roper RS25AQXGN02 SIDE-BY-SIDE REFRIGERATOR
Roper RS25AQXGW00 REFRIGERATOR
Roper RS25AQXGW01 REFRIGERATOR
Roper RS25AQXGW02 SIDE-BY-SIDE REFRIGERATOR
Roper RS25AWXAW00 Refrigerators*
Roper RS25AWXBL00 REFRIGERATOR
Roper RS25AWXBN01 REFRIGERATOR
Roper RS25AWXBW00 REFRIGERATOR
Roper RS25AWXBW01 REFRIGERATOR
Roper RS25AWXDN00 REFRIGERATOR
Roper RS25AWXDW00 REFRIGERATOR
Roper RS25AWXEN00 SIDE-BY-SIDE REFRIGERATOR
Roper RS25AWXEN01 REFRIGERATOR
Roper RS25AWXEW00 SIDE-BY-SIDE REFRIGERATOR
Roper RS25AWXEW01 REFRIGERATOR
Roper RS25AWXVW00 Refrigerators*
Roper RS25AWXVW02 Refrigerators*
Roper RS25AWXWL00 REFRIGERATOR
Roper RS25AWXWW00 REFRIGERATOR
Roper RS25AWXXW00 Refrigerators*
Roper RS25AWXZW00 Refrigerators*
Whirlpool RS25AWXZW01 Refrigerators*
Roper RS25CFXTQ00 REFRIGERATOR
Roper RS25CFXTQ01 REFRIGERATOR
Roper RS25CGXTD00 REFRIGERATOR
 RS2621SW REF - SXS
 RS2622SW REF - SXS
 RS2622SW/XAA REF - SXS
 RS2623BB REF - SXS
 RS2623SH REF - SXS
 RS2623SL REF - SXS
 RS2623VQ REF - SXS
 RS2623WW REF - SXS
 RS2624WW/XAA REF - SXS
 RS2630SH REF - SXS
 RS2630SH/XAA REF - SXS
 RS2630WW REF - SXS
 RS2630WW/XAA REF - SXS
 RS2644SL REF - SXS
 RS2644SW REF - SXS
 RS265LABP REF - SXS
 RS265LAWP REF - SXS
 RS2666SL REF - SXS
 RS2666SW REF - SXS
 RS267LABP REF - SXS
 RS267LABP/XAA REF - SXS
 RS267LASH REF - SXS
 RS267LASH/XAA REF - SXS
 RS269LARS REF - SXS
 RS2777SL REF - SXS
Hoover RS27D011 REF - SXS/I&W
Amana RS30 MWAVE- CNTRTP / STAND ALONE
Whirlpool RS3025XBN0 30" ELECTRIC SLIDE-IN RANGE STANDARD CLEAN OVEN
Whirlpool RS3025XBN1 30" ELECTRIC SLIDE-IN RANGE
Whirlpool RS3025XBW0 30" ELECTRIC SLIDE-IN RANGE STANDARD CLEAN OVEN
Whirlpool RS3025XBW1 30" ELECTRIC SLIDE-IN RANGE
Whirlpool RS310PXBH0 30" ELECTRIC SLIDE-IN RANGE STANDARD CLEAN OVEN
Whirlpool RS310PXEB0 30" ELECTRIC SLIDE-IN RANGE
Whirlpool RS310PXEB1 30" ELECTRIC SLIDE-IN RANGE
Whirlpool RS310PXGN0 ELECTRIC RANGE
Whirlpool RS310PXGW0 ELECTRIC RANGE
Whirlpool RS313PXTT0 Ranges, Electric*
Whirlpool RS313PXYH0 Ranges, Electric*
Whirlpool RS313PXYH2 Ranges, Electric*
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Defrost Timer or defrost circuit part of Control Board? c6timmons Refrigerator & Freezer Repair 0 08-21-2012 12:56 PM
How to install Electronic control board. Part Number: AP4334000 q0987 Refrigerator & Freezer Repair 0 04-13-2011 09:10 PM
High voltage surge damaged the control board,replaced board,compressor still not runn shillion Refrigerator & Freezer Repair 0 11-16-2010 01:18 AM
Control Board-New Part Mauijulz58 Washer Repair 2 05-31-2009 04:58 AM
Replace Control Board for discontinued part kmunro Dishwasher Repair 3 04-10-2009 04:55 AM
