Discuss
Ge water line to the cullighan filter
 in
Refrigerator & Freezer Repair
I have a hole in the top 1/4" water line that leads to the Cullighan filter inside the refridge to
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ge water line to the cullighan filter
  #1 (permalink)
Old 03-02-2013, 05:31 PM
Junior Member
davidconrade is on a distinguished road
Default Ge water line to the cullighan filter
Brand: -brand-   Age: More than 10 years
I have a hole in the top 1/4" water line that leads to the Cullighan filter inside the refridge to the manifold outside under the back right. How do you disconnect the lines from the Cullighan filter.It appears that there is a spline fitting on this.I didnt want to start pulling on stuff.
Thanks,
David
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
instructions on how to change water filter line Freezerman8 Refrigerator & Freezer Repair 0 12-26-2012 12:13 PM
Icemaker/water dispenser don't work with filter in.Fine without filter Maverick8080 Refrigerator & Freezer Repair 0 07-17-2012 01:48 PM
A question please: LINE FILTER on whirlpool washer wh1rpool Washer Repair 2 11-21-2011 06:12 PM
Whirlpool Refrigerator water line filter bypass krjrdj Refrigerator & Freezer Repair 0 02-22-2011 11:48 AM
Replacing water line from inlet valve to filter mike-g2 Refrigerator & Freezer Repair 0 08-08-2010 02:47 PM
