| » Brand new fridge - temp adjustment settings |
Model Number: LGHT2137LE Brand: Frigidaire Age: Less than 1 year
New one week old fridge question: Freezer works fine (5 F) when its dial is set just a bit colder than normal, but fridge part needs to be dialed almost all the way to maximum cool to get it down to 38 F. Is this acceptable or should I call and complain?
Fridge is full, no air flow is blocked. Defrost works, fan works. Door seals good. Lights turn off when door closes. My understanding is the frdige dial simply controls an air baffle, so as long as I can adjust it to get 38 degrees it shouldn't matter how high/low I need to set the dial. On the other hand it seems strange that a normal dial setting doesn't produce 38 F (it produces about 42 F). Ads By Google Related Models |
Quote:
Most cold controls are preset to deliver 38 dgrs.F(+/- 2 dgrs.) when set at the recommended (mid way) settings. The freezer is 0 dgrs.(+/- 2 dgrs) when set. The product temperature in the compartments are usually 2 to 3 dgrs. lower than the air temperature after 24 to 48 hours.When you are making adjustments to the temperature controls, you have to wait 24 hours between settings, to allow for the temperature to equalize. You may want to reset the controls , wait 24 hours and check the product temps with a pocket thermometer ( a can of soda, jar of pickles, etc.and a bag of frozen vegetables works well in the freezer).Then adjust the control, and wait 24 hours, and recheck the temps. recheck the temperature in a few days, If the temperatures were not maintained, then call the servicer.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Thanks Joe.
If I understand your reply correctly, the dial in the fresh food section is the main temperature control and runs the compressor based on temps in the damper area. What does the dial in the freezer control? In my fridge, is the damper a purely passive fixed thing, or does something open and close it? Thanks again Joe! |
Quote:
As you said, the damper is a "passive fixed thing", there are no dampers or doors, etc. The damper consists of a styrofoam block with directional openings to disperse the air in different directions throughout the refrigerator compartment.
__________________
| Display Modes | |
| New Ceramic Element Installed Now No Temp. Adjustment | jyama99 | Oven Repair (including Ranges and Cooktops) | 5 | 10-23-2012 11:52 PM |
| Temp settings keep changing on their own, temp too cold | snakestu | Refrigerator & Freezer Repair | 3 | 04-16-2011 05:35 AM |
| oven temp adjustment | jmiller5927 | Oven Repair (including Ranges and Cooktops) | 0 | 03-30-2010 02:43 PM |
| Gas oven stays on, no temp adjustment | armandoroig | Oven Repair (including Ranges and Cooktops) | 0 | 04-28-2009 08:27 AM |
| no heat generated in any of the 4 temp settings | mikehendrix | Dryer Repair | 2 | 10-07-2008 02:01 AM |
