| » Freezer works, Fridge not cooling, fan still runs |
Quote:
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
Part number: AP4481481 located on the back wall of the refrigerator. Based on inputs from sensors inside the compartments, the control determines when and how long the defrost cycle will occurr. In your case, you will also want to check the "Custom Cool" assembly (lower bin) in the refrigerator, if it is not operating properly it can cause warm refrigerator tmperatures as well. Thanks, the model number is a big assist.
__________________
Jill, Ok, then it's not likely a defrost issue. Now look at the lower right side bottom corner of the freezer, There should be an air tunnel in that area, check and make sure it is not restricted or blocked. If you have a multi meter handy, unplug the harness to the fan motor or slip the meter probes into the connector and check for 12.5 VDC across the yellow and white wires this circuit is the variable speed evaporator fan circuit and should draw at least the 12.5 VDC on the high speed.
__________________
| Display Modes | |
| PLEASE HELP!! Fridge & Freezer Not Cooling- Light Works | KCOUCH | Refrigerator & Freezer Repair | 9 | 02-29-2012 07:12 PM |
| Freezer works fridge not cooling completely | dankam | Refrigerator & Freezer Repair | 1 | 01-23-2011 06:25 AM |
| Freezer works fridge not cooling | denimnlace | Refrigerator & Freezer Repair | 1 | 08-03-2010 01:45 PM |
| Replacing Fridge Fan, freezer works, fridge not cooling | dlake1 | Refrigerator & Freezer Repair | 4 | 07-22-2010 06:01 AM |
| Freezer works poorly fridge inconsistent cooling | billd0419 | Refrigerator & Freezer Repair | 1 | 07-19-2010 12:17 PM |
