| » Kenmore - Fan working, not freezing |
Model Number: 106.63832302 Brand: Kenmore Age: 5 - 10 years
I have a Kenmore Coldspot (model 106.63832302) which stopped working last night. There is some background which might help figure out the problem.
For the past few years that I have had this refrigerator, it would occasionally make a loud click noise (It sounded like the compressor was kicking in). I live in an very old house, so this click and jolt of power was enough to make the lights dim each time it did it. It would do this sometimes multiple times in an hour or just randomly throughout the day. But I got so use to the noise, I didn't even pay attention to it. Also, I don't think the defroster ever worked properly as water drips from the freezer into my refrigerator at the back and I just keep a cup there and occasionally dump out the water. Last night, I noticed the meats in my freezer starting to thaw out. The fan seemed to be still be blowing cold air at the time. I put an ice tube tray in there overnight, and in the morning the water was cold, but not frozen at all. Once I removed everything from the freezer, I could tell the fan was still blowing, but the air was not cold. Can someone help me diagnose the problem? Ads By Google Related Models |
Hi.
You will have to do the continuity test, using the multimeter. Unplug the unit, pull the fridge out, locate the compressor at the bottom. Remove the cover box and start components from the compressor's contacts. Using the multimeter check the continuity between the three compressor's pins and then to the ground. If you read continuity between three pins and no continuity to the ground - replace the start components Part number: 4387938 Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Ice maker not working, freezer not freezing | cheto | Refrigerator & Freezer Repair | 1 | 09-22-2011 05:02 AM |
| Kenmore Not Freezing | Lori Hughes | Refrigerator & Freezer Repair | 0 | 06-28-2011 07:33 AM |
| Not freezing for 2 days, then started working again | o8x8 | Refrigerator & Freezer Repair | 0 | 11-02-2009 09:00 AM |
| Kenmore freezer not freezing | rreagan | Refrigerator & Freezer Repair | 0 | 09-25-2009 03:22 AM |
| Icemaker freezing up, now not working | cbs | Refrigerator & Freezer Repair | 0 | 06-29-2008 08:04 AM |
