| » Freezer not freezing completely |
Model Number: Er8yhmxsl01 Brand: Whirlpool Age: 5 - 10 years
My freezer coils are not completely frozen. If there are 7 coils, two of them have frost. I have vacuumed around the compressor area and cleaned out vents. Not sure what else to check. Thanks
Parts for Whirlpool ER8YHMXSL01 Refrigerator - AppliancePartsPros.com I am assuming that the compressor runs all the time except when it is in defrost. Sounds like you are low on freon. Be sure that the compressor has run for several hours before checking your coils. If you check them shortly after or during a defrost cycle you could come to the wrong conclusion. Below is a good link, check out the example pictures about half way down the page. http://www.applianceaid.com/refriger...old-enough.php If it is low on freon, it will be an expensive repair as you need a pro. Also there is no use adding freon until the leak is found and fixed. Often it makes more sense to put those dollars towards a new unit. I would check the warranty as many units have a longer sealed system warranty.
__________________
| Display Modes | |
| Kenmore Ice Maker replaced twice - Ice not completely freezing | Silverghost | Refrigerator & Freezer Repair | 1 | 01-14-2010 11:49 AM |
| Fridge freezing, Freezer over-freezing | breistl77 | Refrigerator & Freezer Repair | 0 | 12-29-2009 09:12 AM |
| GE - fridge freezing in drawers, freezer not freezing at top, but coils frozen over | jaxcarlson | Refrigerator & Freezer Repair | 0 | 12-01-2009 09:42 AM |
| Freezer not freezing completely | wleuthauser | Refrigerator & Freezer Repair | 3 | 12-01-2009 03:23 AM |
| Sub Zero 201 FD Freezer is not freezing and coils are frosting over/freezing up | badace | Refrigerator & Freezer Repair | 1 | 12-02-2007 09:54 AM |
