Discuss
freezer works, fridge is warm
 in
Refrigerator & Freezer Repair
Recently my fridge has apparently quit cooling but the freezer still freezes as it is supposed to. It appears to
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » freezer works, fridge is warm
  #1 (permalink)
Old 08-13-2007, 07:13 PM
debssanity debssanity is offline
Junior Member
debssanity is on a distinguished road
Default freezer works, fridge is warm
Model Number: HTE18WAAWW-07   Brand: -other-   Age: 1 - 5 years
Recently my fridge has apparently quit cooling but the freezer still freezes as it is supposed to. It appears to be running normal just not keeping anything cold. Anyone ran into this before? This is a Haier 18.2 refrigerator. This is probably basic but I am a novice in this area. Suggestions
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-14-2007, 11:11 AM
Michele Michele is offline
Junior Member
Michele is on a distinguished road
Default Fridge is room temp and Freezer is okay
My Roper refrig./freezer is not working. The freezer is fine but the fridge is warm. What do I do? It seems many people have this problem. I don't have the model # right now. Also, who repairs these appliance?
  #3 (permalink)
Old 09-14-2007, 08:42 PM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
For both of you, go to my comments for Dinatl's GE fridge except ignore last web site.
__________________
  #4 (permalink)
Old 01-01-2008, 01:48 PM
snlphill snlphill is offline
Junior Member
snlphill is on a distinguished road
Default
FOUND IT!
I'm new to this. How do i find Dinatl's posting? I have a Kenmore trio with the same problem: fridge is warm, bottom freezer is fine.
  #5 (permalink)
Old 01-01-2008, 04:55 PM
Senior Expert
APP Volunteer
Default
Post your make and model#.
__________________
  #6 (permalink)
Old 01-01-2008, 05:57 PM
Junior Member
Default
2005 Kenmore Trio Model 596.76523500. Thanks
  #7 (permalink)
Old 01-02-2008, 03:25 AM
Senior Expert
APP Volunteer
Default
Don't even know how this fridg works, hope someone knows
__________________
  #8 (permalink)
Old 01-02-2008, 06:07 PM
techray techray is offline
Junior Member
techray is on a distinguished road
Default
IM very basic terms it sounds like there is an air flow problem from the freezer to the refrigerator section. The easiest things to check for are on the back wall of the freezer look for snowy frost. That indicates either a defrost issue or a possible evaporator fan issue. Unfortunately this may be a job for a service company to repair. check your controls also so that the damper is open, letting air come into the refrig section from the freezer.
  #9 (permalink)
Old 01-02-2008, 08:26 PM
Senior Expert
APP Volunteer
Default
Check your damper control in the fridg. section, might be broken shut. If ok and works, replace the thermistor in the fridg. section P# 12002356. Damper control is P# 67003903
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer and Fridge not cooling/freezing moderdm Refrigerator & Freezer Repair 5 10-04-2008 07:50 PM
Freezer side works but not refridg side atlanta404 Refrigerator & Freezer Repair 4 05-22-2008 06:24 PM
Freezer blows cool but not freezing and refrig is warm Angelicas Refrigerator & Freezer Repair 2 08-08-2007 09:06 PM
Refrig works but freezer is not running cold enough Bill Tagatz Refrigerator & Freezer Repair 1 08-01-2007 06:43 AM
Hot Frame between Fridge and Freezer mshilko Refrigerator & Freezer Repair 3 07-20-2007 01:57 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
