| » Whirlpool freezer icing and defrost circuit |
Model Number: GX5FHTXVB 03 Brand: Whirlpool Age: 1 - 5 years
Hello All,
I have a Whirlpool Gold refrigerator/freezer and the freezer section has been icing up along the vents. At first I thought maybe it was left open slightly and overcompensated resulting in the problem. So I defrosted it in the problem areas with a hair dryer. Temp in fridge returns to normal. Then the problem came back again. So I did some research and decided it was probably something in the defrost circuit. I took the back panel off and found a huge section of ice in the upper right hand corner. The picture below shows this and was actually taken a little after I melted it some. The checked the black wires which run along the bottom, assuming they are the defroster. They measured low ohms and not open so I assume it is OK. The white piece hanging is shown in the parts diagram as a thermistor. Not sure if that could be causing this icing and whether or not this model has an actual defrost timer. If anyone could shed some light on it I would greatly appreciate it. Thanks! Rob ![]() Ads By Google Related Models |
Quote:
You'll need to have a licensed and certified refrigeration technician to evacuate and repair or replace the evaporator and capillary tube, and re charge the system with refrigerant. This may be covered by your factory warranty, so you may want to check your purchase information.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
Great, Hopefully they can help you out. Good Luck,
__________________
UPDATE
When i searched for the whirlpool warranty online it gave me a copy that was about 5 years old for a different fridge. On it the sealed system and compressor were covered for years 2-5. When i found my book that was no longer listed and not covered. I talked to them (customer service) and they are sticking by their new warranty. Then today I got a call from Marc Bitzer's offices. He is the president of whirlpool north america. I wrote a letter to both customer service and Mr. Bitzer. They are going to now cover the it 100%. So it pays to go to the top! Will update again with repair info. |
Quote:
We'll keep an eye out for your next post, hopefully all goes well. Thanks
__________________
| Display Modes | |
| Defrost Timer or defrost circuit part of Control Board? | c6timmons | Refrigerator & Freezer Repair | 0 | 08-21-2012 12:56 PM |
| Defrost drain channel icing up | frankiec | Refrigerator & Freezer Repair | 7 | 12-30-2010 01:23 PM |
| freezer icing up - which circ. board contains the defrost timer? | frankv | Refrigerator & Freezer Repair | 5 | 08-27-2010 04:07 PM |
| Freezer icing up, fridge freezing, thermostat, timer, and defrost heater check out. | sharkytm | Refrigerator & Freezer Repair | 3 | 01-09-2010 09:40 PM |
| Whirlpool Side-by-Side Freezer icing, fridge warm | barkwaffle | Refrigerator & Freezer Repair | 0 | 08-04-2008 07:57 PM |
