| » Kenmore Upright Freezer issues |
Model Number: 253.9264212 Brand: Kenmore Age: 5 - 10 years
I hava a Kenmore upright freezer thats flaking out after being unplugged for sa period of time. When I replugged it up after a couple of hours I went down and checked on it and it was already below freezing at 5 degrees and still cooling. Went down and check on it again a little later on and it was -3.5 inside and still running. The dial was set at 5 out of 6.
Next morning I went back down to check on it and it was 59 degrees and the fan was running but no longer cooling. I tried to turn the dial back up to 6 and check on it again later but it would no longer cool. I unplugged it for a couple of hours and then plugged it back up. Same results, it cooled to below zero within a couple of hours but by the next morning it was just about 60 degrees again. Any ideas? Jimmy Ads By Google Related Models |
Hi.
You need to check two thing for me, please. First - if the compressor is running and not clicking. Second - open the evaporator cover and check what is the frost pattern on the coils.Covered evenly, partially,blocked with snow,ice in one corner? Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
I think I've traced it back to the defrost timer. I tested the Defrost T-Stat and that passed and the next test was the timer and that failed. No reading at all from Common to any of the other posts. Before testing though, when I did take the back off there was frost in the front left corner of the coil but no frost throughout the rest of the coil but that was when I was getting the 60 degree reading.
Hi.
You may have the sealed system problem, the partial restriction in particular. Repair of that kind of the problem will need a pro. If the evaporator coils are not covered with frost - it's not the defrost system failure. Simon.
__________________
The particles or the moisture are flowing inside the sealed system.Sometimes it takes awhile to clog the capillary tube.
Simon.
__________________
You are welcome.
Simon.
__________________
| Display Modes | |
| Kenmore Upright Fridge/Freezer - Freezer not cold enough | gstump | Refrigerator & Freezer Repair | 6 | 06-13-2012 01:51 PM |
| Kenmore Upright Freezer | Cynsative | Refrigerator & Freezer Repair | 0 | 01-24-2011 09:36 AM |
| Kenmore Upright Freezer | baumbarger01@frontier.com | Refrigerator & Freezer Repair | 0 | 12-23-2010 05:46 AM |
| Kenmore 10 upright freezer | sher4osu | Refrigerator & Freezer Repair | 1 | 10-22-2009 04:07 AM |
| Kenmore upright freezer | skpparker25 | Refrigerator & Freezer Repair | 1 | 05-29-2009 07:26 PM |
