REPLACED WATER SUPPLY FILTER NOW ICE MAKER DOESNT not gettig water , water despensor in door works replaced water valve assy . Ice maker water tube is full but no water going into ice maker
Originally Posted by: layjr1604 ...Ice maker water tube is full but no water going into ice maker... Hello, Can you explain it more detailed please? What was the original problem? Did you flash out 2-3 gallons of water after you installed the new filter? Gene.
