Discuss
Amanda fridge fan by condenser not working
 in
Refrigerator & Freezer Repair
The fan next to the condenser is not running. The fridge and the freezer seem to work now. They had
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Amanda fridge fan by condenser not working
  #1 (permalink)
Old 02-04-2013, 07:12 PM
Junior Member
drathaar907 is on a distinguished road
Default Amanda fridge fan by condenser not working
Model Number: BX225W   Brand: Amana   Age: More than 10 years
The fan next to the condenser is not running. The fridge and the freezer seem to work now. They had stopped before, cleaned coils etc. but then noticed this fan was not working. Issue or not?
Ads By Google
Related Models
Amana BX22A2E Ref - Bottom Mounts
Amana BX22A2L Ref - Bottom Mounts
Amana BX22A2W Ref - Bottom Mounts
Amana BX22A5L Ref - Bottom Mounts
Amana BX22A5W Ref - Bottom Mounts
Amana BX22R3E Ref - Bottom Mounts
Amana BX22R3L Ref - Bottom Mounts
Amana BX22R3W Ref - Bottom Mounts
Amana BX22RE Ref - Bottom Mounts
Amana BX22RL Ref - Bottom Mounts
Amana BX22RW Ref - Bottom Mounts
Amana BX22S5E Ref - Bottom Mounts
Amana BX22S5L Ref - Bottom Mounts
Amana BX22S5W Ref - Bottom Mounts
Amana BX22TE Ref - Bottom Mounts
Amana BX22TL Ref - Bottom Mounts
Amana BX22TW Ref - Bottom Mounts
Amana BX518VE Ref - Bottom Mounts
Amana BX518VW Ref - Bottom Mounts
Amana BX521VCPER Ref - Bottom Mounts
Amana BX521VCPSR Ref - Bottom Mounts
Amana BX521VCPWR Ref - Bottom Mounts
Amana BX521VE Ref - Bottom Mounts
Amana BX521VW Ref - Bottom Mounts
Amana BXF19TL Ref - Bottom Mounts
Amana BXF19TW Ref - Bottom Mounts
Amana BXI21VE Ref - Bottom Mounts
Amana BXI21VL Ref - Bottom Mounts
Amana BXI21VW Ref - Bottom Mounts
Amana BXI22S5E Ref - Bottom Mounts
Amana BXI22S5L Ref - Bottom Mounts
Amana BXI22S5W Ref - Bottom Mounts
Whirlpool BYCCD3421W0
Whirlpool BYCCD3421W1
Whirlpool BYCCD3421W2
Whirlpool BYCCD3421W3
Whirlpool BYCCD3921W0
Whirlpool BYCD3722W0
Whirlpool BYCD3722W1
Whirlpool BYCD3723W0
Whirlpool BYCD3723W1
Whirlpool BYCD3723W2
Whirlpool BYCD4932W0
Whirlpool BYCD4933W0
Whirlpool BYCW4271W0
Whirlpool BYCW6292W0
Whirlpool BYCWD6274W0
Whirlpool BYCWD6274W1
Whirlpool BYCWD6274W2
Whirlpool BYCWD6274W3 Washer/dryer Laundry System
Whirlpool BYCWD6274W4 Washer/dryer Laundry System
Amana BZ20QE Ref - Bottom Mounts
Amana BZ20QG Ref - Bottom Mounts
Amana BZ20QL Ref - Bottom Mounts
Amana BZ20QW Ref - Bottom Mounts
Amana BZ20R Ref - Bottom Mounts
Amana BZ20RE Ref - Bottom Mounts
Amana BZ20RG Ref - Bottom Mounts
Amana BZ20RL Ref - Bottom Mounts
Amana BZ20RW Ref - Bottom Mounts
Amana BZ22QE Ref - Bottom Mounts
Amana BZ22QL Ref - Bottom Mounts
Amana BZ22QW Ref - Bottom Mounts
Amana BZ22R3E Ref - Bottom Mounts
Amana BZ22R3L Ref - Bottom Mounts
Amana BZ22R3W Ref - Bottom Mounts
Amana BZ22R5L Ref - Bottom Mounts
Amana BZ22R5W Ref - Bottom Mounts
Amana BZ22RE Ref - Bottom Mounts
Amana BZ22RL Ref - Bottom Mounts
Amana BZ22RW Ref - Bottom Mounts
Jenn-Air C Surface Unit - Ddraft Ele
Amana C-11 Freezer - Chest
Amana C-15 Freezer - Chest
Amana C-19 Freezer - Chest
Amana C-28 Freezer - Chest
Hardwick C-413 Surface Unit - Gas
Hardwick C-414 Surface Unit - Gas
Hardwick C-423 Surface Unit - Gas
Hardwick C-424 Surface Unit - Gas
Hardwick C-433 Surface Unit - Gas
Hardwick C-434 Surface Unit - Gas
Hardwick C-443 Surface Unit - Gas
Hardwick C-444 Surface Unit - Gas
Jenn-Air C100 Surface Unit - Ddraft Ele
Amana C100DW Freezer - Chest
Amana C100FW Freezer - Chest
  #2 (permalink)
Old 02-04-2013, 07:17 PM
Junior Member
Default Model # BX22S5W
Sorry this is the correct model number.... I entered it wrong BX22S5W
  #3 (permalink)
Old 02-05-2013, 02:54 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Parts for Amana BX22S5W - AppliancePartsPros.com
See the attachment for the wiring diagram.
Yes it is a problem.
The unit will have problems maintaining the temperatures and the compressor will run longer and hot which is hard on it.
As you can see in the wiring diagram the evaporator and the condenser fans are wired in parallel with the compressor so both fans should run when the compressor is on.
When the compressor is on check the voltage across the fan.
If it is 120 volts, replace the fan.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Amanda. Fridge acting up Marty McFly Refrigerator & Freezer Repair 1 07-11-2011 03:36 AM
FRIDGE warm freezer fine possible condenser fan PATRICK OBRIEN Refrigerator & Freezer Repair 1 05-15-2011 05:11 AM
FRIDGE warm freezer fine possible condenser fan PATRICK OBRIEN Refrigerator & Freezer Repair 1 05-15-2011 05:10 AM
magic chef fridge condenser fan motor 95peterbuilt Refrigerator & Freezer Repair 1 08-26-2010 05:21 AM
Amanda Ice Maker ajcustoms Refrigerator & Freezer Repair 0 11-23-2009 03:04 PM
