| » Ice Maker supply tube freezes up |
Model Number: 596.51673100 Brand: Kenmore Age: 5 - 10 years
I have a Kenmore side by side fridge. This unit has a fairly thick - perhaps 1 inch in diameter tube that carries water from the back of the freezer to the icemaker. On several occasions, I have found that the tube becomes frozen - clogged with ice. When this happens, obviously, we don't get ice made because the water can't get to the icemaker.
Other times, instead of the tube, ice forms in the icemaker "inlet" - where the tube meets the ice maker. When this happens the water flows everwhere but the icemaker - covering our food with water that becomes an icy mess. Usually I end up removing the icemaker and letting the inlet thaw out. Also, I have at times removed the supply tube from the back and let it thaw out as well. Once the ice is gone, I put the icemaker and supply tube back in, and things begin working fine. For a while. Eventually the ice will form again and I need to repeat the process. Is this a flaw with this model? Is there some way to keep this ice from forming? Ads By Google Related Models |
Hi.
Try to shorten the inlet tube just a bit, so it won't touch the icemaker wall. If that doesn't help - replace the water inlet valve. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Ice maker Fill Tube drips water than freezes up | nevadamike | Refrigerator & Freezer Repair | 2 | 01-10-2013 02:47 PM |
| supply tube to icemaker freezes | townsendtim | Refrigerator & Freezer Repair | 1 | 10-21-2012 01:50 PM |
| Ice maker supply tube frozen | ttsnuffy | Refrigerator & Freezer Repair | 1 | 10-25-2010 05:27 AM |
| ice maker supply freezes up | vernonpayne | Refrigerator & Freezer Repair | 2 | 09-01-2009 02:47 PM |
| Ice Maker Supply Tube Freezing?? | Kevin Dolezal | Refrigerator & Freezer Repair | 2 | 05-01-2008 02:42 AM |
