| » Fridgidaire Fridge too cold, freezer appears OK |
Model Number: frs26r4ab6 Brand: Frigidaire Age: 5 - 10 years
Hello.
Frigidaire FRS26R4AB6 ...Refrigerator freezes food unless I turn fridge control dial to off or extremely low. Once turned off/down fridge warms before manually resetting via dial.... chasing tail continues. Damper between freezer and fridge "seems" to stay open too long. Damper will close if fridge control is turned to, or close to, off. Will once again blow cold air if dial is set appropriately. Previously I emptied entire unit, both sides, and dried all 24 hours+ in attempt to start clean and dry. Freezer currently @ 6 degrees +/-2. Both freezer and fridge "dials" below factory settings when fridge freezes. Freezer aspect itself seems to cycle OK AND keep cold. No frost in freezer evident either before or after 24 hour thaw. Ice maker works fine. Hopefully correct info with all that bloviating. :-) Any ideas? Ads By Google Related Models |
HI.
Most likely you need to replace the refrigerator cold control Part number: 240383703 It's #21 on the diagram Controls parts for Frigidaire FRS26R4AB6 - AppliancePartsPros.com Use the old insulation sleeve. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Freezer Cold But Not Freezing; Fridge Compartment Cold & Seems Fine | ChuckM12 | Refrigerator & Freezer Repair | 1 | 08-29-2012 07:51 AM |
| Kernmore fridge/freezer.. Freezer fine fridge too cold | poolsidepaul | Refrigerator & Freezer Repair | 7 | 04-19-2011 03:16 PM |
| Fridgidaire Freezer/fridge | peggy777 | Refrigerator & Freezer Repair | 1 | 08-17-2009 05:28 AM |
| Fridgidaire FRS22ZGH freezer works/fridge won't cool | WMOYLAN | Refrigerator & Freezer Repair | 1 | 01-28-2008 02:24 PM |
| Fridge & Freezer Cycle Cold To Warm Back To Cold | terkel | Refrigerator & Freezer Repair | 1 | 09-25-2007 02:58 AM |
