| » Replacing Tubing to Filter Head |
Model Number: GSS25VGMC WW Brand: GE Age: More than 10 years
Hi my name is Rob,
My son has a GSS25VGMC WW refrigerator and the Water Supply tube that connects to the house copper tubing is cracked. I wanted to buy a new tube, the tube has a modified compression fitting. With a molded ferrel. the plastic tube had a Molded Ferral, not the separate collar type found in most compression fittings. It looked just like the one in the video about replacing the Double Outlet Water Valve ******************** Number PS304374, not the valve but the tube. Part Number: MFG Part Number: So they recommended this part: AP4494516 for $15.03 Pro TJ915PEX 15' Pex I/m Hookup - AppliancePartsPros.com It looks like it would work but this tube goes into the Filter Head and I can’t see how to remove the part of the old tube from the Filter Head. Is this even possible and if not is there some type of Coupling that I could get so that I could Splice the New Molded Ferral end to the Old Tube that goes to the Filter head. Thank you Ads By Google Related Models |
Hello,
I'm afraid I did not get clear which tube are you looking for: to connect the refrigerator to the house water line or to connect the water inlet valve to the water filter? Here are the breakdown diagrams and Parts for GE GSS25VGMCWW Refrigerator - AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Hi Rob,
There is something wrong. The home water supply must be connected to the refrigerator water inlet valve on the back of the refrigerator. The another tube should go from the water inlet valve to the filter. Gene.
__________________
| Display Modes | |
| clogged water filter head | dbellis | Refrigerator & Freezer Repair | 0 | 11-10-2012 08:21 AM |
| replacing Head water filter | jmyfry | Refrigerator & Freezer Repair | 4 | 04-29-2011 04:01 PM |
| Water filter tubing repair | retmet | Refrigerator & Freezer Repair | 1 | 03-15-2011 08:20 AM |
| Procedure for replacing water filter head? | mountcomp | Refrigerator & Freezer Repair | 1 | 03-12-2009 04:08 PM |
| water filter head assembly GE | fwjg180 | Refrigerator & Freezer Repair | 0 | 03-25-2008 10:10 AM |
