| » Amana frigerator freezes all food and beverages! |
Model Number: ARB2217CW Brand: Amana Age: 1 - 5 years
My Amana bottom freezer refrigerator worked okay until 4 days ago when it froze everything in the refrigerator part. Model # ARB2217CW; Manufacturer No. PARB2217CWD. I unplugged it for 24 hours and it refroze within 12 hours. When I plugged it back in, it blew cold from the back. It seems that the compressor is constantly on and I can see cold smoke blowing from the front (by the light) where the temperature set is. It is set on lowest; 1-2. Can someone help?
Related Models |
Replacement parts for AMANA ARB2217CW | AppliancePartsPros.com Could be a couple things. Check that the damper between the freezer and fresh foods sections is itclosing. See the "Controls" section. Note this is a mechanical thermostat that opens/closes the vents. Could the the main thermostat is is shot (contacts welded together) Check the freezer temp, should be 0 to 8 degrees F. If much lower then it is probably the thermostat. I would lean towards the first option. Perhaps the reason that the compressor runs continuously is that it cannot keep the freezer at the proper temp when a large amount of the cold air is being diverted to the fresh food section. Here are a couple good sites with additional info. Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com http://www.applianceaid.com/refrigerator.html
__________________
| Display Modes | |
| Refrigerator Freezes Food | quadkellys | Refrigerator & Freezer Repair | 4 | 06-12-2009 12:42 PM |
| refrigerator side freezes food | target | Refrigerator & Freezer Repair | 1 | 03-16-2009 12:15 PM |
| Fresh food freezes | Hubstl | Refrigerator & Freezer Repair | 1 | 01-30-2009 08:04 PM |
| Frigerator Food Section Too Cold | ronbo | Refrigerator & Freezer Repair | 1 | 01-06-2009 04:16 PM |
| fridge freezes food | pirate626 | Refrigerator & Freezer Repair | 0 | 07-31-2007 03:24 PM |
