I am getting a small drop of water coming out from under the left side of the dispenser framing and running down the front of the refrigerator door. it will leak even if the power is shut off and I believe the power has nothing to do with the plastic water line. it will leak at a rate of one drop per 45 seconds.
I have never seen anything like this since most leaks occur within the dispenser. I am guessing that the plastic water supply line is probably brittle and has possibly cracked slightly. This new refrigerator sat idle in a Florida home for four years and in the garage for two and a half years.
Has anyone had this issue? And if so how can i remedy this? How do you get to the hose if it is within the door itself.
AL
