Discuss
Whirlpool side by side refrigerator not cooling
 in
Refrigerator & Freezer Repair
Two months ago I had the compressor replaced by Alabama Power co and everything worked fine except it was very
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Whirlpool side by side refrigerator not cooling
  #1 (permalink)
Old 10-01-2009, 05:42 AM
Junior Member
etaylor is on a distinguished road
Default Whirlpool side by side refrigerator not cooling
Brand: Whirlpool   Age: 5 - 10 years
Two months ago I had the compressor replaced by Alabama Power co and everything worked fine except it was very noisy at times.Two days ago the refrigerator temp went to 50 and stayed for a while,i noticed the compressor would cut off about three times within an hour but the fan stayed on.now the temp inside is 65 degrees but the compressor runs and every 8 hours the compressor and fan stops and it goes into defrost.I noticed that the compressor gets too hot to touch, i had to run my fingers under cold water.The freon is not low according to the refrigerator tech,he seems to think i have a defrost problem but there is no frost in the freezer and it goes into defrost every 8 hours and the compressor runs the entire 8 hours.What could cause this? I really need to know before i spend out any more money. Thanks for any help
Ads By Google
  #2 (permalink)
Old 10-01-2009, 12:33 PM
Frank / APP Team's Avatar
Senior Expert
Frank / APP Team is on a distinguished road
Default
Quote:
If there is no frost on the evap coil after running for 8 hrs. you have a sealed system problem. What makes the tech think it's a defrost problem? Did he happen to comment it was running and defrosting the same time?
Your best bet is to get Alabama Power back out there while the compressor still has warranty on it in case that's the problem.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 10-01-2009, 03:24 PM
Junior Member
Default
Thanks Frank, the Tech from Alabama came back did some more test and said it was the compressor again and ordered the part. There was no frost pattern.I really appreciate guys like you Frank it help people like me. The Tech was ready to order another part and treat this like a new service call. Thanks again
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Refrigerator Side by Side not cooling rhaniyur Refrigerator & Freezer Repair 3 12-24-2009 06:56 AM
Refrigerator Side by Side not cooling eeedwards Refrigerator & Freezer Repair 0 06-02-2009 11:24 AM
Whirlpool side by side not cooling/freezing hartshaped Refrigerator & Freezer Repair 2 05-07-2009 03:28 PM
whirlpool refrigerator side by side icemaker makes little or no ice T-ROY Refrigerator & Freezer Repair 1 11-07-2008 01:37 PM
side by side refrigerator stopped cooling and freezing bbcowboy Refrigerator & Freezer Repair 3 03-21-2008 06:02 PM
