Discuss
Kenmore Water Valve/Ice maker ???
 in
Refrigerator & Freezer Repair
Any Ideas? I have a Kenmore Ice Maker that has been giving me trouble. It stared a month ago when
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kenmore Water Valve/Ice maker ???
  #1 (permalink)
Old 01-30-2013, 09:20 AM
Junior Member
redram99v8 is on a distinguished road
Default Kenmore Water Valve/Ice maker ???
Model Number: 106.56564400   Brand: Kenmore   Age: 5 - 10 years
Any Ideas? I have a Kenmore Ice Maker that has been giving me trouble. It stared a month ago when I switched out the water filter. My water flow rate slowed down and I assumed the filter was bad I waited about 3 weeks and no difference. The ice machine began making little ice cubes but only small ones and even then 2 to 3 cubes when there is a 8 tray ice maker. Yesterday I replaced the filter with a fast fill "pur" filter. The previous new one was not a fast fill "pur" filter. The water rate did increase a little but still not to a flow rate I had before. Also the ice machine showed no difference and still was making little to no ice. After doing some research I did the optics test for the Ice maker P.C. board and it showed it was bad. So I replaced both sides of the P.C. board yesterday and WHAM the ice machine started making Full Size Ice cubes but still only 5 at a time when there is 8 cubes. I Have watched the water flow into the ice maker when it fills and seems to be slow to me. Also My in door water dispenser is still slower then it was when all this started last month. So this makes me think the water valve. However here is the questions that have me wondering is it the valve. If I take the "pur" filter out. The water rate is fast and flows through the in door water dispenser at a fast rate which has me thinking, IS ??? this truly the water valve problem? Also the water dispenser in the door has a small drip in it from time to time after using it that continues for some time after using it. Not enough to spill on the floor but enough to fill the back of the drip tray which makes me think that IT is the water valve. I just dont want to spend $75 dollars on a new valve if it is not going to make a difference. Can anyone help?
Ads By Google
Related Models
Kenmore 106.5721160  COLDSPOT FREEZER
Kenmore 106.5721200  COLDSPOT FREEZER
Kenmore 106.5721201  COLDSPOT FREEZER
Kenmore 106.5821160  COLDSPOT FREEZER
Kenmore 106.5821200  COLDSPOT FREEZER
Kenmore 106.5825120  COLDSPOT FREEZER
Kenmore 106.5825121  COLDSPOT FREEZER
Kenmore 106.5825160  COLDSPOT FREEZER
Kenmore 106.5825200  COLDSPOT FREEZER
Kenmore 106.5827120  COLDSPOT FREEZER
Kenmore 106.5829100  MIRA-COLD FREEZER
Kenmore 106.5923120  COLDSPOT FREEZERS
Kenmore 106.5923121  COLDSPOT FREEZERS
Kenmore 106.5923160  COLDSPOT FREEZERS
Kenmore 106.5923161  COLDSPOT FREEZERS
Kenmore 106.5923200  COLDSPOT FREEZERS
Kenmore 106.5923201  COLDSPOT FREEZERS
Kenmore 106.5927120  COLDSPOT FREEZERS
Kenmore 106.5927121  COLDSPOT FREEZERS
Kenmore 106.5927160  COLDSPOT FREEZER
Kenmore 106.5927161  COLDSPOT FREEZER
Kenmore 106.5927200  COLDSPOT FREEZERS
Kenmore 106.5927201  COLDSPOT FREEZERS
Kenmore 106.5928100  COLDSPOT FREEZER
Kenmore 106.5929100  COLDSPOT FREEZER
Kenmore 106.6021100  COLDSPOT FREEZER
Kenmore 106.6021101  COLDSPOT FREEZER
Kenmore 106.6023120  COLDSPOT FREEZER
Kenmore 106.6025120  COLDSPOT FREEZER
Kenmore 106.6025121  COLDSPOT FREEZER
Kenmore 106.6025150  COLDSPOT FREEZER
Kenmore 106.6025151  COLDSPOT FREEZER
Kenmore 106.6025160  COLDSPOT FREEZER
Kenmore 106.6025161  COLDSPOT FREEZER
Kenmore 106.6025200  COLDSPOT FREEZER
Kenmore 106.6025201  COLDSPOT FREEZER
Kenmore 106.6121100  COLDSPOT FREEZER
Kenmore 106.6123120  COLDSPOT FREEZER
Kenmore 106.6123170  COLDSPOT FREEZER
Kenmore 106.6123210  COLDSPOT FREEZER
Kenmore 106.6125160  COLDSPOT FREEZER
Kenmore 106.615120  COLDSPOT FREEZER 10.0 CUBIC FEET
Kenmore 106.6221100  COLDSPOT FREEZER
Kenmore 106.6221101  COLDSPOT FREEZER
Kenmore 106.6221102  COLDSPOT FREEZER
Kenmore 106.622150  COLDSPOT FREEZER
Kenmore 106.6222170  COLDSPOT FREEZER
Kenmore 106.6222171  COLDSPOT FREEZER
Kenmore 106.6222172  COLDSPOT FREEZER
Kenmore 106.6222173  COLDSPOT FREEZER
Kenmore 106.6223120  COLDSPOT FREEZER
Kenmore 106.6223170  COLDSPOT FREEZER
Kenmore 106.6223210  COLDSPOT FREEZER
Kenmore 106.6225120  COLDSPOT FREEZER
Kenmore 106.6225170  COLDSPOT FREEZER
Kenmore 106.6226130  COLDSPOT FREEZER
Kenmore 106.6226150  COLDSPOT FREEZER
Kenmore 106.6226151  COLDSPOT FREEZER
Kenmore 106.6226152  COLDSPOT FREEZER
Kenmore 106.6226153  COLDSPOT FREEZER
Kenmore 106.6226170  COLDSPOT FREEZER
Kenmore 106.6227130  COLDSPOT FREEZER
Kenmore 106.625120  COLDSPOT FREEZER-10.7 CUBIC FEET
Kenmore 106.625121  COLDSPOT FREEZER-10.7 CUBIC FEET
Kenmore 106.625140  COLDSPOT FREEZER-12.4 CUBIC FEET
Kenmore 106.625201  COLDSPOT FREEZER-15.7 CUBIC FEET
Kenmore 106.625202  COLDSPOT VERTICAL FREEZER 15.7 CUBIC FEET
Kenmore 106.625210  COLDPOINT FREEZER-15.7 CUBIC FEET
Kenmore 106.625220  COLDSPOT FREEZER-15.7 CUBIC FEET
Kenmore 106.625221  COLDSPOT FREEZER-15.7 CUBIC FEET
Kenmore 106.625222  COLDSPOT FREEZER-15.7 CUBIC FEET
Kenmore 106.625240  COLDSPOT FREEZERS 15.3 CUBIC FEET
Kenmore 106.625242  COLDSPOT FREEZERS 15.3 CUBIC FEET
Kenmore 106.625250  COLDSPOT FREEZERS 15.3 CUBIC FEET
Kenmore 106.711060  COLDSPOT FREEZER-6.6 CUBIC FEET
Kenmore 106.712060  COLDSPOT FREEZER
Kenmore 106.712061  COLDSPOT FREEZER
Kenmore 106.720120  COLDSPOT FREEZER-10.0 CUBIC FEET
Kenmore 106.720122  COLDSPOT FREEZER-10.0 CUBIC FEET
Kenmore 106.720123  COLDSPOT FREEZER-10.0 CUBIC FEET
Kenmore 106.720124  COLDSPOT FREEZER 10.0 CUBIC FEET
Kenmore 106.720140  COLDSPOT FREEZER 12.5 CUBIC FEET
Kenmore 106.720141  COLDSPOT FREEZER-12.5 CUBIC FEET
Kenmore 106.720200  COLDSPOT FREEZER-15.8 CUBIC FEET
Kenmore 106.720210  COLDSPOT FREEZER-15.8 CUBIC FEET
Kenmore 106.720211  COLDSPOT FREEZER-15.8 CUBIC FEET
Kenmore 106.720220  COLDSPOT FREEZER-15.8 CUBIC FEET
Kenmore 106.720221  COLDSPOT FREEZER-15.8 CUBIC FEET
Kenmore 106.720240  COLDSPOT FREEZER-17.4 CUBIC FEET
Kenmore 106.720241  COLDSPOT FREEZER-15.3 CUBIC FEET
Kenmore 106.720300  COLDSPOT FREEZER-15.3 CUBIC FEET
Kenmore 106.720420  COLDSPOT FREEZER-17.4 CUBIC FEET
Kenmore 106.720421  COLDSPOT FREEZER-17.4 CUBIC FEET
Kenmore 106.720440  COLDSPOT FREEZERS-17.0 CUBIC FEET
Kenmore 106.720441  COLDSPOT FREEZERS-17.0 CUBIC FEET
Kenmore 106.720442  COLDSPOT FREEZERS
Kenmore 106.720450  COLDSPOT FREEZERS-17.0 CUBIC FEET
Kenmore 106.720451  COLDSPOT FREEZERS-17.0 CUBIC FEET
Kenmore 106.720452  COLDSPOT FREEZERS
Kenmore 106.720460  COLDSPOT FREEZERS
Kenmore 106.720461  COLDSPOT FREEZERS 17.0 CUBIC FEET
Kenmore 106.720470  COLDSPOT FREEZERS
Kenmore 106.720471  COLDSPOT FREEZERS 17.0 CUBIC FEET
Kenmore 106.720480  COLDSPOT FREEZERS-17.0 CUBIC FEET
Kenmore 106.720481  COLDSPOT FREEZERS-17.0 CUBIC FEET
Kenmore 106.720490  COLDSPOT FREEZERS-17.0 CUBIC FEET
Kenmore 106.720491  COLDSPOT FREEZERS-17.0 CUBIC FEET
Kenmore 106.720550  COLDSPOT FREEZERS-17.0 CUBIC FEET
Kenmore 106.720551  COLDSPOT FREEZERS-17.0 CUBIC FEET
Kenmore 106.720552  COLDSPOT FREEZERS
Kenmore 106.720620  COLDSPOT FREEZER-21.0 CUBIC FEET
Kenmore 106.720640  COLDSPOT FREEZER-20.3 CUBIC FEET
Kenmore 106.720641  COLDSPOT FREEZER-20.3 CUBIC FEET
Kenmore 106.721040  COLDSPOT FREEZER 3.9 CUBIC FEET
Kenmore 106.721120  COLDSPOT FREEZER 10.0 CUBIC FEET
Kenmore 106.721121  COLDSPOT FREEZER 10.0 CUBIC FEET
Kenmore 106.721140  COLDSPOT FREEZER 12.5 CUBIC FEET
Kenmore 106.721200  COLDSPOT FREEZER 15.8 CUBIC FEET
Kenmore 106.721201  COLDSPOT FREEZER 15.8 CUBIC FEET
Kenmore 106.721202  COLDSPOT FREEZER 15.8 CUBIC FEET
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
ice maker water valve does not shut off on occasion burning out the valve sentepede Refrigerator & Freezer Repair 1 08-28-2012 04:17 PM
ice maker water valve lpeek Refrigerator & Freezer Repair 1 03-07-2012 12:28 PM
Kenmore Ice Maker --no ice--maker or water control valve cps.extra Refrigerator & Freezer Repair 0 08-13-2011 08:59 AM
Water Valve for Ice Maker sanders Refrigerator & Freezer Repair 4 08-15-2010 05:27 PM
Ice Maker water valve? hskurnick Refrigerator & Freezer Repair 0 06-08-2009 01:34 PM
