Discuss
Fridgidare Upright Freezer Problem
 in
Refrigerator & Freezer Repair
Freezer now works after replacing several elec. parts and fresh freon chg.,but now it goes down to the desired temp
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Fridgidare Upright Freezer Problem
  #1 (permalink)
Old 01-29-2013, 06:38 PM
Junior Member
mmm26815 is on a distinguished road
Default Fridgidare Upright Freezer Problem
Model Number: GLFU2067FW5   Brand: Frigidaire   Age: 1 - 5 years
Freezer now works after replacing several elec. parts and fresh freon chg.,but now it goes down to the desired temp setting and the left side ( looking from the front to back ) about midway up the side gets VERY HOT to touch ??? is there any wiring or components built into the sides of the freezer ?? or is that normal ?? we never noticed that before and as I said it will go down to the desired setting with no problems.. any help would be greatly appreciated.. I've replaced the control board and elec. cont. module along with the defrost therm. to cover all the bases. it worked for while then the alarm went off and temp was going up.. realized it was low on freon, taped in, chg' up with about 3-4 oz's, turned on, comp. kicked in high side line getting hot to the touch low side and to evap cold with light frost, temp went down to -5 deg for several days, had the evap cover just sitting in position so i could remove and use freon leak detector, no leaks, sys press the same as after rechg, but now happend to notice the left side gets very hot in several places ??? HELP !! AND THANKS !!! MCM
Related Models
Frigidaire GLFU2067FW5 FREEZER
Frigidaire GLFU2067FW6 FREEZER
Frigidaire GLFU2067FW7 FREEZER
Frigidaire GLFU2067FW8 FREEZER
Frigidaire GLGC30S8ABA Frigidaire/cooktop
Frigidaire GLGC30S8ABB Frigidaire/gas Cooktop
Frigidaire GLGC30S8AQA Frigidaire/cooktop
Frigidaire GLGC30S8AQB Frigidaire/gas Cooktop
Frigidaire GLGC30S8ASA Frigidaire/cooktop
Frigidaire GLGC30S8ASB Frigidaire/gas Cooktop
Frigidaire GLGC30S8CBA Frigidaire/gas Cooktop
Frigidaire GLGC30S8CBB Frigidaire/gas Cooktop
Frigidaire GLGC30S8CQA Frigidaire/gas Cooktop
Frigidaire GLGC30S8CQB Frigidaire/gas Cooktop
Frigidaire GLGC30S8CSA Frigidaire/gas Cooktop
Frigidaire GLGC30S8CSB Frigidaire/gas Cooktop
Frigidaire GLGC30S8EBA Frigidaire/gas Cooktop
Frigidaire GLGC30S8EQA Frigidaire/gas Cooktop
Frigidaire GLGC30S8ESA Frigidaire/gas Cooktop
Frigidaire GLGC30S8KBA Frigidaire/gas Cooktop
Frigidaire GLGC30S8KBB Frigidaire/gas Cooktop
Frigidaire GLGC30S8KSA Frigidaire/gas Cooktop
Frigidaire GLGC30S8KSB Frigidaire/gas Cooktop
Frigidaire GLGC30S9EBA Frigidaire/gas Cooktop
Frigidaire GLGC30S9EQA Frigidaire/gas Cooktop
Frigidaire GLGC30S9ESA Frigidaire/gas Cooktop
Frigidaire GLGC36S8ABA Frigidaire/gas Cooktop
Frigidaire GLGC36S8ABB Frigidaire/gas Cooktop
Frigidaire GLGC36S8AQA Frigidaire/gas Cooktop
Frigidaire GLGC36S8AQB Frigidaire/gas Cooktop
Frigidaire GLGC36S8ASA Frigidaire/gas Cooktop
Frigidaire GLGC36S8ASB Frigidaire/gas Cooktop
Frigidaire GLGC36S8CBA Frigidaire/gas Cooktop
Frigidaire GLGC36S8CBB Frigidaire/gas Cooktop
Frigidaire GLGC36S8CQA Frigidaire/gas Cooktop
Frigidaire GLGC36S8CQB Frigidaire/gas Cooktop
Frigidaire GLGC36S8CSA Frigidaire/gas Cooktop
Frigidaire GLGC36S8CSB Frigidaire/gas Cooktop
Frigidaire GLGC36S8EBA Frigidaire/gas Cooktop
Frigidaire GLGC36S8EQA Frigidaire/gas Cooktop
Frigidaire GLGC36S8ESA Frigidaire/gas Cooktop
Frigidaire GLGC36S8KBA Frigidaire/gas Cooktop
Frigidaire GLGC36S8KSA Frigidaire/gas Cooktop
Frigidaire GLGC36S9EBA Frigidaire/gas Cooktop
Frigidaire GLGC36S9EQA Frigidaire/gas Cooktop
Frigidaire GLGC36S9ESA Frigidaire/gas Cooktop
Frigidaire GLGF366ABA Frigidaire/range
Frigidaire GLGF366ABB Frigidaire/range
Frigidaire GLGF366ABC Frigidaire/gas Range
Frigidaire GLGF366ABD Frigidaire/gas Range
Frigidaire GLGF366AQA Frigidaire/range
Frigidaire GLGF366AQB Frigidaire/range
Frigidaire GLGF366AQC Frigidaire/gas Range
Frigidaire GLGF366AQD Frigidaire/gas Range
Frigidaire GLGF366ASA Frigidaire/range
Frigidaire GLGF366ASB Frigidaire/range
Frigidaire GLGF366ASC Frigidaire/gas Range
Frigidaire GLGF366ASD Frigidaire/gas Range
Frigidaire GLGF376DBA Frigidaire/gas Range
Frigidaire GLGF376DBB Frigidaire/gas Range
Frigidaire GLGF376DBC Frigidaire/range
Frigidaire GLGF376DBE Frigidaire/range
Frigidaire GLGF376DBF Frigidaire/range
Frigidaire GLGF376DBG Frigidaire/range
Frigidaire GLGF376DBH Frigidaire/range
Frigidaire GLGF376DBJ GAS RANGE
Frigidaire GLGF376DBK GAS RANGE
Frigidaire GLGF376DBM GAS RANGE
Frigidaire GLGF376DBN GAS RANGE
Frigidaire GLGF376DBR GAS RANGE
Frigidaire GLGF376DCA Frigidaire/gas Range
Frigidaire GLGF376DCB Frigidaire/range
Frigidaire GLGF376DCC Frigidaire/range
Frigidaire GLGF376DCD Frigidaire/range
Frigidaire GLGF376DCF Frigidaire/range
Frigidaire GLGF376DQA Frigidaire/gas Range
Frigidaire GLGF376DQB Frigidaire/gas Range
Frigidaire GLGF376DQC Frigidaire/range
Frigidaire GLGF376DQE Frigidaire/range
Frigidaire GLGF376DQF Frigidaire/range
Frigidaire GLGF376DQG Frigidaire/range
Frigidaire GLGF376DQH Frigidaire/range
Frigidaire GLGF376DQJ GAS RANGE
Frigidaire GLGF376DQK GAS RANGE
Frigidaire GLGF376DQM GAS RANGE
Frigidaire GLGF376DSA Frigidaire/gas Range
Frigidaire GLGF376DSB Frigidaire/gas Range
Frigidaire GLGF376DSC Frigidaire/range
Frigidaire GLGF376DSE Frigidaire/range
Frigidaire GLGF376DSF Frigidaire/range
Frigidaire GLGF376DSG Frigidaire/range
Frigidaire GLGF376DSH Frigidaire/range
Frigidaire GLGF376DSJ GAS RANGE
Frigidaire GLGF376DSK GAS RANGE
Frigidaire GLGF376DSM GAS RANGE
Frigidaire GLGF376DSN GAS RANGE
Frigidaire GLGF376DSR GAS RANGE
Frigidaire GLGF377ABA Frigidaire/gas Range
Frigidaire GLGF377ABC Frigidaire/range
Frigidaire GLGF377ABD Frigidaire/gas Range
Frigidaire GLGF377ABE Frigidaire/gas Range
Frigidaire GLGF377ABF Frigidaire/gas Range
Frigidaire GLGF377ABG Frigidaire/gas Range
Frigidaire GLGF377AQA Frigidaire/gas Range
Frigidaire GLGF377AQC Frigidaire/range
Frigidaire GLGF377AQD Frigidaire/gas Range
Frigidaire GLGF377AQE Frigidaire/gas Range
Frigidaire GLGF377AQF Frigidaire/gas Range
Frigidaire GLGF377AQG Frigidaire/gas Range
Frigidaire GLGF377ASA Frigidaire/gas Range
Frigidaire GLGF377ASC Frigidaire/range
Frigidaire GLGF377ASD Frigidaire/gas Range
Frigidaire GLGF377ASE Frigidaire/gas Range
Frigidaire GLGF377ASF Frigidaire/gas Range
Frigidaire GLGF377ASG Frigidaire/gas Range
Frigidaire GLGF377CBA Frigidaire/gas Range
Frigidaire GLGF377CBB Frigidaire/gas Range
Frigidaire GLGF377CBD Frigidaire/gas Range
Frigidaire GLGF377CBE Frigidaire/gas Range
Frigidaire GLGF377CQA Frigidaire/gas Range
  #2 (permalink)
Old 01-30-2013, 04:37 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Did you suck down the high and low sides with a vacumm pump and install a new dryer?
__________________
  #3 (permalink)
Old 01-31-2013, 01:44 PM
Junior Member
Default
yes, have a vacumn pump and installed new drier... what confuses me is what is in the left side wall ?? wires, copper lines ?? that would get that hot ?? thx, for your reply, mcm
  #4 (permalink)
Old 01-31-2013, 04:04 PM
Senior Expert
APP Volunteer
Default
If the compressor current is higher than spec and runing hot, you may have non-compressables in the system.
__________________
  #5 (permalink)
Old 02-01-2013, 10:03 AM
Junior Member
Default
??? i guess recover, flush, new drier and recharge ?? maybe some trash on the other side of drier ?? again thanks, mcm
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Upright Fridge/Freezer - Freezer not cold enough gstump Refrigerator & Freezer Repair 6 06-13-2012 01:51 PM
Fridgidare Freezer and Fridge not staying cold Shane5223 Refrigerator & Freezer Repair 10 11-16-2010 04:03 PM
Upright freezer problem Jeremyh Refrigerator & Freezer Repair 1 10-23-2009 06:31 PM
