Discuss
Frigidare SxS not cooling
 in
Refrigerator & Freezer Repair
I have a Frigidare SxS not cooling/freezing. I first noticed that the ice maker was not making ice and then
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Frigidare SxS not cooling
  #1 (permalink)
Old 01-26-2013, 06:20 PM
Junior Member
dwainej is on a distinguished road
Default Frigidare SxS not cooling
Model Number: GLRS64ZEW7   Brand: Frigidaire   Age: 5 - 10 years
I have a Frigidare SxS not cooling/freezing. I first noticed that the ice maker was not making ice and then after a day or so noticed that the fridge side was not keeping milk cold and then all the stuff in the freezer was thawing out. I pulled the inside back cover off on the freezer side to gain access to the coil and there was a little bit of ice on the top 1/4 or so. After "Googling" the issue (which eventually led me here), I decided to change the defrost thermostat and it still does not get cold.
When I first plug the fridge in the condensor fan runs, I can feel/hear the compressor start up as well as a slight vibration, and the evaporater fan works as well. I can press the door switch 5 times and it appears to go into defrost mode, although the heater does not feel warm to the touch. I have done an ohm check on the heater and its around 30.5 ohms and the voltage is 0 when I first plug the fridge in and about 95VAC when I put it into defrost mode (via the switch). I can turn the freezer control knob all the way to zero and it acts normal (fans shut off, compressor shuts off, etc...)
Thoughts??
Ads By Google
Related Models
Frigidaire GLRS64ZEW7 Frigidaire/refrigerator
Frigidaire GLRS64ZEW8 Frigidaire/refrigerator
Frigidaire GLRS64ZEW9 Frigidaire/refrigerator
Frigidaire GLRS64ZEWA Frigidaire/refrigerator
Frigidaire GLRSF236JB0 Frg(v1) / Refrigerator
Frigidaire GLRSF236JB1 Frg(v1) / Refrigerator
Frigidaire GLRSF236JB2
Frigidaire GLRSF236JD0 Frg(v2) / Refrigerator
Frigidaire GLRSF236JD1 Frg(v2) / Refrigerator
Frigidaire GLRSF236JD2
Frigidaire GLRSF236JW0 Frg(v3) / Refrigerator
Frigidaire GLRSF236JW1 Frg(v3) / Refrigerator
Frigidaire GLRSF236JW2
Frigidaire GLRSF266JB0 Frg(v1) / Refrigerator
Frigidaire GLRSF266JB1 Frg(v1) / Refrigerator
Frigidaire GLRSF266JB2 Frigidaire/refrigerator
Frigidaire GLRSF266JD0 Frg(v2) / Refrigerator
Frigidaire GLRSF266JD1 Frg(v2) / Refrigerator
Frigidaire GLRSF266JD2 Frigidaire/refrigerator
Frigidaire GLRSF266JW0 Frg(v3) / Refrigerator
Frigidaire GLRSF266JW1 Frg(v3) / Refrigerator
Frigidaire GLRSF266JW2 Frigidaire/refrigerator
Frigidaire GLRT13TEB0 Frigidaire/refrigerator
Frigidaire GLRT13TEB1 Frigidaire/refrigerator
Frigidaire GLRT13TEB2 Frigidaire/refrigerator
Frigidaire GLRT13TEB3 Frigidaire/refrigerator
Frigidaire GLRT13TEB4 Frigidaire/refrigerator
Frigidaire GLRT13TEB5 Frigidaire/refrigerator
Frigidaire GLRT13TEB7 Frigidaire/refrigerator
Frigidaire GLRT13TEB8 Frigidaire/refrigerator
Frigidaire GLRT13TEK0 Frigidaire/refrigerator
Frigidaire GLRT13TEK1 Frigidaire/refrigerator
Frigidaire GLRT13TEK2 Frigidaire/refrigerator
Frigidaire GLRT13TEK4 Frigidaire/refrigerator
Frigidaire GLRT13TEK5 Frigidaire/refrigerator
Frigidaire GLRT13TEK6 Frigidaire/refrigerator
Frigidaire GLRT13TEK7 Frigidaire/refrigerator
Frigidaire GLRT13TEK8 Frigidaire/refrigerator
Frigidaire GLRT13TEQ0 Frigidaire/refrigerator
Frigidaire GLRT13TEQ1 Frigidaire/refrigerator
Frigidaire GLRT13TEQ2 Frigidaire/refrigerator
Frigidaire GLRT13TEQ3 Frigidaire/refrigerator
Frigidaire GLRT13TEQ4 Frigidaire/refrigerator
Frigidaire GLRT13TEQ5 Frigidaire/refrigerator
Frigidaire GLRT13TEQ7 Frigidaire/refrigerator
Frigidaire GLRT13TEQ8 Frigidaire/refrigerator
Frigidaire GLRT13TES0 Frigidaire/refrigerator
Frigidaire GLRT13TES1 Frigidaire/refrigerator
Frigidaire GLRT13TES2 Frigidaire/refrigerator
Frigidaire GLRT13TES4 Frigidaire/refrigerator
Frigidaire GLRT13TES5 Frigidaire/refrigerator
Frigidaire GLRT13TES6 Frigidaire/refrigerator
Frigidaire GLRT13TES7 Frigidaire/refrigerator
Frigidaire GLRT13TES8 Frigidaire/refrigerator
Frigidaire GLRT13TEW0 Frigidaire/refrigerator
Frigidaire GLRT13TEW1 Frigidaire/refrigerator
Frigidaire GLRT13TEW2 Frigidaire/refrigerator
Frigidaire GLRT13TEW3 Frigidaire/refrigerator
Frigidaire GLRT13TEW4 Frigidaire/refrigerator
Frigidaire GLRT13TEW5 Frigidaire/refrigerator
Frigidaire GLRT13TEW6 Frigidaire/refrigerator
Frigidaire GLRT13TEW7 Frigidaire/refrigerator
Frigidaire GLRT13TEW8 Frigidaire/refrigerator
Frigidaire GLRT180SAQ0 Frigidaire/refrigerator
Frigidaire GLRT180SAW0 Frigidaire/refrigerator
Frigidaire GLRT181SAQ0 Frigidaire/refrigerator
Frigidaire GLRT181SAW0 Frigidaire/refrigerator
Frigidaire GLRT182SAB1 Frigidaire/refrigerator
Frigidaire GLRT182SAB3 Frigidaire/refrigerator
Frigidaire GLRT182SAB5 Frigidaire/refrigerator
Frigidaire GLRT182SAQ1 Frigidaire/refrigerator
Frigidaire GLRT182SAQ2 Frigidaire/refrigerator
Frigidaire GLRT182SAQ3 Frigidaire/refrigerator
Frigidaire GLRT182SAQ4 Frigidaire/refrigerator
Frigidaire GLRT182SAQ5 Frigidaire/refrigerator
Frigidaire GLRT182SAW1 Frigidaire/refrigerator
Frigidaire GLRT182SAW2 Frigidaire/refrigerator
Frigidaire GLRT182SAW3 Frigidaire/refrigerator
Frigidaire GLRT182SAW4 Frigidaire/refrigerator
Frigidaire GLRT182SAW5 Frigidaire/refrigerator
Frigidaire GLRT183SBB5 Frigidaire/rerigerator
Frigidaire GLRT183SBQ1 Frigidaire/refrigerator
Frigidaire GLRT183SBQ5 Frigidaire/rerigerator
Frigidaire GLRT183SBW1 Frigidaire/refrigerator
Frigidaire GLRT183SBW5 Frigidaire/rerigerator
Frigidaire GLRT183TDB1 Frigidaire/refrigerator
Frigidaire GLRT183TDB3 Frigidaire/refrigerator
Frigidaire GLRT183TDB5 Frigidaire/refrigerator
Frigidaire GLRT183TDB7 Frigidaire/refrigerator
Frigidaire GLRT183TDBA Frigidaire/refrigerator
Frigidaire GLRT183TDBB Frigidaire/refrigerator
Frigidaire GLRT183TDBC Frigidaire/refrigerator
Frigidaire GLRT183TDBD Frigidaire/refrigerator
Frigidaire GLRT183TDBE Frigidaire/refrigerator
Frigidaire GLRT183TDBF Frigidaire/refrigerator
Frigidaire GLRT183TDBG Frigidaire/refrigerator
Frigidaire GLRT183TDBH Frigidaire/refrigerator
Frigidaire GLRT183TDBK Frigidaire/refrigerator
Frigidaire GLRT183TDBL Frigidaire/refrigerator
Frigidaire GLRT183TDBM Frigidaire/refrigerator
Frigidaire GLRT183TDQ0 Frigidaire/refrigerator
Frigidaire GLRT183TDQ1 Frigidaire/refrigerator
Frigidaire GLRT183TDQ3 Frigidaire/refrigerator
Frigidaire GLRT183TDQ4 Frigidaire/refrigerator
Frigidaire GLRT183TDQ5 Frigidaire/refrigerator
Frigidaire GLRT183TDQ6 Frigidaire/refrigerator
Frigidaire GLRT183TDQ7 Frigidaire/refrigerator
Frigidaire GLRT183TDQ8 Frigidaire/refrigerator
Frigidaire GLRT183TDQA Frigidaire/refrigerator
Frigidaire GLRT183TDQB Frigidaire/refrigerator
Frigidaire GLRT183TDQC Frigidaire/refrigerator
Frigidaire GLRT183TDQD Frigidaire/refrigerator
Frigidaire GLRT183TDQE Frigidaire/refrigerator
Frigidaire GLRT183TDQF Frigidaire/refrigerator
Frigidaire GLRT183TDQG Frigidaire/refrigerator
Frigidaire GLRT183TDQH Frigidaire/refrigerator
Frigidaire GLRT183TDQK Frigidaire/refrigerator
Frigidaire GLRT183TDQL Frigidaire/refrigerator
Frigidaire GLRT183TDQM Frigidaire/refrigerator
Frigidaire GLRT183TDW0 Frigidaire/refrigerator
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidare Waynegreen Dishwasher Repair 0 09-26-2011 06:54 PM
frigidare lloyd t petersen Refrigerator & Freezer Repair 0 09-06-2011 12:47 PM
Frigidare desertspirit Refrigerator & Freezer Repair 1 01-10-2011 03:56 AM
frigidare mmolin1 Oven Repair (including Ranges and Cooktops) 0 10-22-2010 02:35 PM
Frigidare jwilliams20019 Oven Repair (including Ranges and Cooktops) 1 12-23-2009 01:24 PM
