Cooling issues
Came home to find cooling issues. Backwal of freezer has frost and ice maker has had issues for a little while. Not making proper ice.
And Fridge is not cooling good either. I have been just keeping condensor fan and lines cleaned from dust. Thoughts on correction? |
You have a mechanical type defrost timer usually behind the control panel. Look for a hole and stick a flat bladed screwdriver in it and turn it till the compressor turns off. If you get no defrost action, you most probably have a bad defrost limiter clipped to the top of the evaporator. If you get defrost, replace the timer.
Quote:
replacing the timer i guess will be my next thing. should i expect more issues? is this sign? THANKS FOR THE HELP. My #1 place to get information and parts! |
Well, never defrosted. So opened up back wall. Found broken glass sleeve from element and finding thermostat bad. So replaceing asap! I think Timer is good. So hopefully this will get it.
| All times are GMT -7. The time now is 10:13 AM. |
