Discuss
Refrigerator Side constant at 30 degrees
 in
Refrigerator & Freezer Repair
I have a 10-year-old GE PSF26NGNAWW refrigerator that stopped working. I replaced the main control board (WR55X10942) and everything works
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrigerator Side constant at 30 degrees
  #1 (permalink)
Old 01-24-2013, 09:27 AM
Junior Member
retiredSFer is on a distinguished road
Default Refrigerator Side constant at 30 degrees
Brand: GE   Age: 5 - 10 years
I have a 10-year-old GE PSF26NGNAWW refrigerator that stopped working. I replaced the main control board (WR55X10942) and everything works fine now except the refrigerator side remains at a constant 30 degrees. I set the freezer side to 0 degrees and it holds constant at 0 degrees. I set the refrigerator side to 37 degrees, but it holds constant at 30 degrees, occasionally 29-31degrees. Please help.
  #2 (permalink)
Old 01-24-2013, 01:26 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Have you red the instructions which came with the control board replacement? You may need to cut one wire to the thermistor.
If you are good on the model number and no adjustments should be done, then most likely there is a broken air damper control in the fresh food side
Part number: WR49X10091
Here are the breakdown diagrams and Fresh Food Section parts for GE PSF26NGNAWW - AppliancePartsPros.com
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 01-24-2013, 04:41 PM
Junior Member
Default
Quote:
Originally Posted by Simon / APP Team View Post
Hi.
Post the results.
Simon.
Thank you for your quick response. According to the installation instructions, the thermistor wire must be cut or elimated on all bottom freezers. I have a side freezer, but will take the cover off and look for a wire in pin 2.
Roger
  #4 (permalink)
Old 01-24-2013, 05:12 PM
Expert
Default
Hi, Roger.
In the instructions came with the control board there is the list of the model and serial numbers beside the bottom mounts which require the cutting.
You did not respond to the second part of my post mentioning the air damper control and that's where the problem is if the board doesn't need the adjustment.
Simon.
__________________
  #5 (permalink)
Old 01-24-2013, 05:37 PM
Junior Member
Default
Hi, Roger.
Simon.
Simon,
I just took the cover off the control board and looked at the pictures I took of my original board before I removed and replaced it. No wires at all in pin 8 and 9 on both new and old board. My serial number starts with LD which is not on the list. It appears that I have a broken air damper control as you mention. Before my refrigerator stopped working I had no problem maintaining the temperatures on both side. Refrigerator stopped working so I replaced the control board and that is when the refrigerator side remained at a constant 30 degrees. I will order a damper control board from you site and see what happens.
Roger
  #6 (permalink)
Old 01-25-2013, 09:27 AM
Expert
Default
Good luck.
Simon.
__________________
  #7 (permalink)
Old 01-25-2013, 09:32 AM
Junior Member
Default
Good luck.
Simon.
Thank you for your assistance.
Roger
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Samsung Refrigerator by side stuck at 50 Degrees bigvegas4u Refrigerator & Freezer Repair 1 10-13-2013 07:45 AM
LG Refrigerator/freezer stays at constant 59 degrees jstinson78 Refrigerator & Freezer Repair 0 01-02-2013 07:42 PM
Freezer -4 degrees and refrigerator 48 degrees FDAR Refrigerator & Freezer Repair 0 11-19-2011 03:58 PM
Freezer @ 15 degrees refrigerator @37 degrees mfoxgrover Refrigerator & Freezer Repair 2 10-05-2010 02:54 PM
GE side by side compressor runs constant now Fixitcheap Refrigerator & Freezer Repair 2 01-29-2010 06:44 AM
