Discuss
Amana compressor motor hot to the touch
 in
Refrigerator & Freezer Repair
The unit has been giving us trouble. It doesn't cool. Replaced the overload relay in May, December and again today.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Amana compressor motor hot to the touch
  #1 (permalink)
Old 01-22-2013, 05:28 PM
Junior Member
limberlost is on a distinguished road
Default Amana compressor motor hot to the touch
Model Number: ARB8057CB   Brand: Amana   Age: More than 10 years
The unit has been giving us trouble. It doesn't cool. Replaced the overload relay in May, December and again today. Noticed the compressor runs hot to the touch and wondering if this is abnormal or normal? To have to replace the overload relay 3 times in 8 months seems very unusual to me....Parts Supplier said it was a defective device and replaced the december unit under warranty. p/n is 67005560 Overload
Wonder if something else may going on that I'm not aware of????
Related Models
Amana ARB8057CB REF - BOTTOM MOUNTS
Amana ARB8057CC REF - BOTTOM MOUNTS
Amana ARB8057CSL REF - BOTTOM MOUNTS
Amana ARB8057CSR REF - BOTTOM MOUNTS
Amana ARB8057CW REF - BOTTOM MOUNTS
Amana ARB9058CB REF - BOTTOM MOUNTS
Amana ARB9058CS REF - BOTTOM MOUNTS
Amana ARB9058CW REF - BOTTOM MOUNTS
Amana ARB9059CS REF - BOTTOM MOUNTS
Amana ARC-1 RANGE- S/C S/I DDRAFT GAS
Amana ARC-100 RANGE- S/C S/I DDRAFT GAS
Amana ARC-100B RANGE- S/C S/I DDRAFT GAS
Amana ARC-1B RANGE- S/C S/I DDRAFT GAS
Amana ARC-2 RANGE- S/C S/I DDRAFT GAS
Amana ARC-2B RANGE- S/C S/I DDRAFT GAS
Amana ARC-506 RANGE- S/C S/I DDRAFT ELE
Amana ARC100B RANGE- S/C S/I DDRAFT ELE
Amana ARC100D RANGE- S/C S/I DDRAFT ELE
Amana ARC1B RANGE- S/C S/I DDRAFT ELE
Amana ARC502W RANGE- S/C S/I DDRAFT ELE
Amana ARC505 RANGE- S/C F/S ELE
Amana ARC505B RANGE- S/C S/I DDRAFT ELE
Amana ARC515 RANGE- S/C S/I DDRAFT ELE
Amana ARC515 RANGE- S/C S/I DDRAFT GAS
Amana ARC700E Range - S/c S/i Ddraft Ele
Amana ARC700E RANGE- S/C S/I DDRAFT ELE
Amana ARC700LL RANGE- S/C S/I DDRAFT ELE
Amana ARC700WW RANGE- S/C S/I DDRAFT ELE
Amana ARDS800E RANGE- S/C S/I DDRAFT ELE
Amana ARDS800WW RANGE- S/C S/I DDRAFT ELE
Amana ARDS801E RANGE- S/C S/I DDRAFT ELE
Amana ARDS801WW RANGE- S/C S/I DDRAFT ELE
Amana ARDS802E RANGE- S/C S/I DDRAFT ELE
Amana ARDS802SS RANGE- S/C S/I DDRAFT ELE
Amana ARDS802WW RANGE- S/C S/I DDRAFT ELE
Amana ARE14 MISC / ACCESSORY
Amana ARE640 RANGE- S/C S/I DDRAFT GAS
Amana ARE640 RANGE- S/C S/I DDRAFT ELE
Amana ARE650 RANGE- S/C S/I DDRAFT GAS
Amana ARE650 RANGE- S/C S/I DDRAFT ELE
Amana ARG3600L RANGE- S/C S/I DDRAFT GAS
Amana ARG3600LL RANGE- S/C S/I DDRAFT GAS
Amana ARG3600W RANGE- S/C S/I DDRAFT GAS
Amana ARG3600WW RANGE- S/C S/I DDRAFT GAS
Amana ARG3601L RANGE- S/C S/I DDRAFT GAS
Amana ARG3601LL RANGE- S/C S/I DDRAFT GAS
Amana ARG3601W RANGE- S/C S/I DDRAFT GAS
Amana ARG3601WW RANGE- S/C S/I DDRAFT GAS
Whirlpool ARG483WP01 Refrigerators*
Whirlpool ARG490 REFRIGERATOR
Whirlpool ARG4901 SIDE-BY-SIDE REFRIGERATOR
Amana ARG7102C RANGE- S/C S/I DDRAFT GAS
Amana ARG7102L RANGE- S/C S/I DDRAFT GAS
Amana ARG7102L RANGE- S/C F/S GAS
Amana ARG7102L Range - S/c S/i Ddraft Gas
Amana ARG7102W RANGE- S/C F/S GAS
Amana ARG7102W RANGE- S/C S/I DDRAFT GAS
Amana ARG7200L RANGE- S/C S/I DDRAFT GAS
Amana ARG7200W RANGE- S/C S/I DDRAFT GAS
Amana ARG7202 E RANGE- S/C S/I DDRAFT GAS
  #2 (permalink)
Old 01-23-2013, 02:39 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
If the condensing fan next to the compressor is running, the compressor vibrating, but the condenser coils cool, you probably have sealed system problems.
If compressor not vibrating, you may have a blown start winding in the compressor or you wired it wrong.
If the new start device looks like the part 12555902, then you probably did not wire it wrong.
__________________
  #3 (permalink)
Old 01-23-2013, 03:02 PM
Junior Member
Default
Condenser fan running, compressor runs intermittently, the part number I provided is what a service person installed back in May and is similar, but not the same as, part 12555902. This 67005560 is genuine Whirlpool part according to the packaging and has a code number 122611.
It is not clear to me why the compressor runs intermittently. And when it doesn't the overload relay clicks.
  #4 (permalink)
Old 01-24-2013, 01:46 AM
Senior Expert
APP Volunteer
Default
Your compressor's temperature is exceedint the trip point of the overload in the start device and clicking open. If the compressor is not vibrating, try a new start device. If you have a meter, you can verify if it is bad.
__________________
  #5 (permalink)
Old 01-24-2013, 06:24 PM
Junior Member
Default
My trusty ohm meter gave me readings of 3 and 5 ohms on the winding pins. Single pin on Top being common I hope. So I unplugged everything and let the compressor cool overnight and restarted it today. Cold it started working just fine...only to stop completely 15 minutes later. Even the condensing fan stopped operating...the light inside is still on. How can I determine if the temperature sensor is working correctly? I am wondering if the overload relay is similar but not correct enough and I should go back the the p/n you provided...would this matter?
  #6 (permalink)
Old 01-25-2013, 01:46 AM
Senior Expert
APP Volunteer
Default
The fact it started proves your compressor start device works, but it also indicates your compressor is bad, overheating.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana compressor motor will not start blinkedty Refrigerator & Freezer Repair 1 04-16-2011 06:50 AM
Refrigerator compressor won't run but is hot to the touch b2010 Refrigerator & Freezer Repair 0 09-28-2010 10:26 AM
compressor to hot to touch rgarton Refrigerator & Freezer Repair 2 07-15-2009 08:34 PM
Refrigerator compressor too hot to touch r.miller999 Refrigerator & Freezer Repair 1 05-29-2009 05:57 AM
Motor next to Compressor burnt - Amana Side by Side Refrigerator hlitebrite Refrigerator & Freezer Repair 4 03-03-2009 08:49 AM
