| » Refrigerator leaking |
Model Number: ET19DKXFN00 Brand: Whirlpool Age: More than 10 years
Hi, this refrigerator/freezer is leaking maybe a half-cup of water per day into the refrigerator from the (upper) freezer section.
I understand from several threads that this is likely due to a plugged drain. With this model unit, are the instructions generally to access the pan and drain from inside the freezer as other posts have suggested for other Whirlpool models? There appears to be no access panel in the back other than at the base of the unit. I really appreciate your help. Ads By Google Related Models |
Hi Tom,
Remove the ice cube tray shelf. Remove the screws securing the freezer floor and pull the floor out. Remove the screws securing the rear panel and pull the panel out. The drain hole is under the evaporator coils. You can use a hair dryer to defrost it and a turkey baster with hot water to make sure it goes through. Here are the breakdown diagrams and Parts for Whirlpool ET19DKXFN00 Refrigerator - AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
You are welcome. Thank you for your good words.
__________________
Hi, Gene - sorry to bother you, but another question because I can't tell from the parts schematic - how do I tell when I've cleared the drainage line? I don't know how long the tube is - I can only see down the drain maybe 3/4 inch. Sorry, never mind - I think I can see the pan in there - the drainage "tube" itself is maybe only a half-inch long itself, right?
Run some hot water through the drain using a turkey baster. Pull the refrigerator out of the wall. Remove the rear cover and you should see the other end of the drain hose. Make sure it's clean too.
__________________
I'm glad to hear I could help you out. If there is anything else we can help you with, drop us a line.
__________________
| Display Modes | |
| Refrigerator leaking | Barbara Lim | Refrigerator & Freezer Repair | 1 | 01-16-2012 03:41 PM |
| Refrigerator Leaking from freezer into refrigerator | BootsieP | Refrigerator & Freezer Repair | 1 | 05-06-2011 03:37 AM |
| Refrigerator Leaking | moron | Refrigerator & Freezer Repair | 0 | 09-14-2010 06:07 PM |
| leaking refrigerator | TSTUCKMAN | Refrigerator & Freezer Repair | 2 | 08-25-2010 07:32 AM |
| leaking refrigerator | dougkail | Refrigerator & Freezer Repair | 1 | 11-16-2009 07:20 AM |
