| » mr. harry grupp |
Model Number: mbf2256kew3 Brand: Maytag Age: 1 - 5 years
I have a bottom freezer Maytag. It works fine, but i keep getting ice buildup on the bottom. I have to break it up and remove by hand. I don't see any water under the fridge in the evaplorating tray. thanks
In the bottom of the freezer compartment, at the rear, is a drain hole which leads to a tube. This is probably clogged. Usually, all it needs is to be warmed with a blow dryer (set on low, you don't want to get it hot, just warm enough to melt the ice).
Then, use a thin bottle brush and pour a little water down it to clean out any debris. If I recall correctly, you'll need to empty the freezer and remove the shelves and coil cover to see the drain hole. Good Luck |
| Display Modes | |
| harry o. | chefharryo | Dryer Repair | 1 | 04-27-2010 05:57 PM |
| harry o. | chefharryo | Dryer Repair | 0 | 04-24-2010 06:08 PM |
| harry o. | chefharryo | Dryer Repair | 0 | 04-24-2010 05:56 PM |
| harry o. | chefharryo | Oven Repair (including Ranges and Cooktops) | 0 | 04-24-2010 05:50 PM |
| Harry | HarryD | Washer Repair | 0 | 09-15-2008 01:30 PM |
