How to access dispenser control board on WP fridge
The diagram for this unit does not show any visible clips or screws holding on the faceplate for the dispenser board. I want to be cautious in removing it, as those parts are not currently available. Any tricks to removing these piece(s) so I can replace the problem dispenser board?
Hello,
Try to use the following instructions: "The front dispenser cover can be removed by inserting a screw driver blade into the two slots on the bottom side of the cover. By gently turning the blade, the cover will snap free at the bottom and can be slid upward to be removed." Here are the breakdown diagrams and Parts for Whirlpool ED2KHAXVB01 Refrigerator - AppliancePartsPros.com Gene. |
Thanks much, Gene. Worked like a charm!
You are welcome. I'm glad it did work for you.
Gene. |
| All times are GMT -7. The time now is 04:44 PM. |
